VideoHelp.com Forum
    Hi guys, I need you help in the following question:
    Is there any way to cut raw h264 files frame-accurately?
    If there isn't, What's the best method to cut h264 files as precisely as possible?
    No there isn't. The GOP has to be re-constructed if the cut isn't at end of the GOP (before the next GOP). No current software does this properly. If you re-encode the whole thing then cuts can be frame accurate.
    For cutting raw h.264 file, you could use DGIndex. In a container, you could use mkvmerge for mkv, avidemux for mp4 and mkv, or tsmuxer, ts sniper, h264 ts cutter, tsdoctor or tspe for transport streams. These are only keyframe accurate
    Thanks for your quick reply, that's what I was afraid of.
  1. Suggestions to cut raw H.264 video streams?
    By AshleyQuick in forum Editing
    Last Post: 28th Jan 2011, 13:28
  2. List of HD-DVD with h.264 video streams?
    By mshilly in forum Blu-ray Ripping
    Last Post: 25th Jan 2009, 01:19
  3. RAW blu-ray 264 video stream to MP4 ? Problem
    By scoobdriver in forum Blu-ray Ripping
    Last Post: 18th Nov 2008, 18:19
  4. Replies: 8
    Last Post: 6th Aug 2008, 15:06
  5. MPEG2 > H.264 video converter with Dual audio streams?
    By idsane in forum Video Conversion
    Last Post: 30th Jul 2008, 14:36
