I thought it was year day month but it can't possibly be right as the year is off in these files
month-day-year_hour-minute. but it's possible you changed it as you can make it any way you want.
I did not change it from the default but it is displaying a 30 where the year should be, so that must be the day but none of the others fit the year either
then i'd guess someone played with the time/date setting in the camera menu. the timestamp comes from the tape.
Based on the WinDV web site, year-month-day_hour-minute-second looks to be the default.
And, to follow up on what aedipuss mentioned, if the timestamp info from the camera is incorrect, check and see if it needs a new "backup" battery. Usually a small, coin-shaped battery (like the CMOS battery in a PC) - BTDT on my Canon MiniDV.
I checked the cam and it is set right, the battery is good and there is no possibility that someone played around with it
Thankyou for helping
Tape damage or head misalignment can sometimes cause a misread of the time/date data before it has any visible/audible effect on the content itself.
Cheers,
David.
Play your captured file through the Enosoft DV Processor - it will show you the date/time/timecode within the DV.
John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
Strange audio and date issue with WinDV
By spotty in forum CapturingReplies: 5Last Post: 16th May 2011, 17:00 -
Extracting Recording Date and Time from captured .mov file
By rcgrabbag in forum MacReplies: 0Last Post: 15th Nov 2008, 08:11 -
*.avi files captured from miniDV tapes with WinDV no longer plays
By gho in forum Software PlayingReplies: 5Last Post: 1st Jul 2008, 21:51 -
Date/ Time do not appear on my captured videos
By hulmufti in forum CapturingReplies: 3Last Post: 18th Nov 2007, 10:46 -
Date & Time Captured by DV out of Video Camera
By Mazen in forum CapturingReplies: 17Last Post: 13th Oct 2007, 10:00
