VideoHelp.com Forum
Thread: Flash to DVD
    I've successfully encoded one flash video to produce a VIDEO_TS folder but another flash video from a different source only produces a file with extension .flv.ff.m2v and no VIDEO_TS folder is produced. The .flf.ff.m2v file is without sound. In both cases I used the mpeg2enc encoder. Any ideas please?
    The log end below looks suspicious; due to the message "cannot save file" but I've written both files above to the same location.
    INFO: [mpeg2enc] Worker: getting
    INFO: [mpeg2enc] Enc1 7054 7054(14) P q=4.55 [4% Intra]
    INFO: [mpeg2enc] NEW GOP INIT length 15
    INFO: [mpeg2enc] Working: stripe 0/1 1
    INFO: [mpeg2enc] Worker: stripe 0 done
    INFO: [mpeg2enc] Enc1 7055 7055( 0) I q=3.90 [100% Intra]
    INFO: [yuvscaler] End of stream!
    INFO: [yuvscaler] Normal exit: end of stream with frame number 7058!
    INFO: [mpeg2enc] Enc1 7056 7056( 1) P q=6.44 [18% Intra]
    INFO: [mpeg2enc] Signaling last frame = 7057
    INFO: [mpeg2enc] Enc1 7057 7057( 2) P q=8.59 [32% Intra]
    INFO: [mpeg2enc] Sequence end inserted
    INFO: [mpeg2enc] Guesstimated final muxed size = 142306016
    INFO: [mpeg2enc] SHUTDOWN worker
    error: could not create save file!
  2. Explorer Case's Avatar
    The log doesn't reveal (to me) a reason for this to occur.
    This is normal for .m2v files, as the video is converted first. After that, the audio should be converted to a separate file (often .ac3). Finally these two should get muxed together into a .mpg file.
    I wonder what this '.flf' file is, as Flash video files usually have a '.flv' suffix.
    Are you sure the source file has audio (see ffmpegX Summary tab), and is it properly recognized? What is the audio codec in the source file?
  1. DVD on USB flash drive
    By jjis in forum Newbie / General discussions
    Last Post: 29th Jun 2011, 23:34
  2. flash (swf) to dvd menu
    By freenow in forum Authoring (DVD)
    Last Post: 4th Jan 2009, 00:36
  3. DVD to FLV (Flash 8 Video)
    By foochuck in forum Video Conversion
    Last Post: 27th Jun 2007, 06:20
  4. DVD Menu Flash problem
    By jcubz in forum Newbie / General discussions
    Last Post: 15th May 2007, 22:26
