VideoHelp.com Forum
  1. Member buckethead's Avatar
    Can tmpgenc author 3.0 be used to reliably burn dvd+r dl disks without too many headaches ?
    Does anyone have any firsthand experience ?
    Thanks guys and gals.
    why take a chance? imgburn is free and the best burning app around.
  3. Member buckethead's Avatar
    aedipuss :
    Since this is a Christmas project for a friend and time is of the essence, can I use tmpgenc which I already know to build the audio and video ts files and then use imgburn to burn ? I promise later to learn imgburn because it does seem to be the consensus burning software of choice ...
  4. I'm a Poll Super Moderator johns0's Avatar
    Use tmpgenc to output the folder and then burn the VIDEO_TS with imgburn.
    Ben Johnson-I didnt take any stereos!
  5. Member buckethead's Avatar
    I created a video_ts file using tmpgenc author 3.0. I burned this to a verbatim dvd+r dl using imgburn. It worked perfectly on the first try. I'm shocked when anything I attempt works on the first try.
    Thanks, all !!
  1. TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
    By artyjeffrey in forum Authoring (DVD)
    Last Post: 8th Nov 2008, 13:23
  2. Replies: 1
    Last Post: 20th Aug 2008, 02:41
  3. Replies: 1
    Last Post: 22nd May 2008, 10:22
  4. Replies: 5
    Last Post: 18th Nov 2007, 15:07
