I'm trying to watch a movie (Qayamet Se Qayamet Tak) which was ripped into two files. I found subtitles for both parts. Unfortunately, the last 18 lines of part 1 are in the subtitle file for part 2, at the very beginning. It looks like either the .srt or the .avi was just split in the wrong place, or something. I've edited the .srt files to move the misplaced 18 lines back to part 1, but I can't get the timing right.
When I first edited the .srt files I simply copied the first 18 lines of part 2 into the .srt for part 1, and created time codes for the newly added lines by adjusting the time codes that were in the .srt for part 2. (For instance, the first of the 18 lines starts at 00:00:02,098 in .srt 2. I moved the line into .srt 1 and added 00:00:02,098 onto the time of the last line into .srt 1.) This strategy failed, and now I'm turning to you. Hopefully one of you can help me.
Thanks in advance!
Haiku's creator
Must have had seven fingers
On his middle hand
If using Subtitle Workshop, pretty easy to resync a few lines like that.
Read its manual on how to adjust times.
AlanHK, thanks very much for the reply. Unfortunately, Subtitle Workshop is Windows-only, and I'm running Ubuntu. Any ideas for another program that would help?
Haiku's creator
On his middle hand
How did the srt not work after adding the lines and editing the timecode?If the last line on srt 1 was say 567 for axample,then the next following lines have to start with 568,569.... so if they werent changed and still have 1,2 3 then it will confuse the order to be displayed.
Ben Johnson-I didnt take any stereos!
What does "failed" mean?Originally Posted by Tinkering
Didn't work at all, or just the wrong timing?
Also the offset should be more than "02,098 " from the last subtitle.
You should find the exact duration of the first video and add 02,098 to that.
Also the subtitle numbers should increment by one each time.
Subtitle Workshop fixes up details like that, but you can do it in a text editor with patience.
Post in the Linux forum (http://forum.videohelp.com/linux-f19.html) to ask about suitable software, or see http://www.videohelp.com/tools/secti...ux-video-tools. That lists Jubler, which I've never used, but looks like it will do the job.
All the subs, all the time
By VenusAndMars in forum SubtitleReplies: 6Last Post: 5th Apr 2010, 02:11 -
Help calculation seconds from Time Code.
By lberezinski in forum ProgrammingReplies: 2Last Post: 30th Mar 2010, 12:53 -
Negative time code error...
By impmon2 in forum SubtitleReplies: 5Last Post: 21st Mar 2008, 09:22 -
Fixing Time Playback Issue in MPEG2
By NightFire in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2008, 23:52 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 22:08
