I have a dual layer DVD I want to burn, but every time I click on Write, I keep getting the message:
"Unknown media in the DVD. Please insert blank recordable media!"
There is NOTHING in the blank DVD-R DL. How can I burn the data now?
Don't burn DL media with anything but ImgBurn (it's free). If you don't like that answer, you won't find help here.
I strongly discourage the use of DVD-R DL. You really should use DVD+R DL discs instead. If you must use -R for some reason, then ONLY use Verbatim. You should be aware that burners must use some special settings to burn DVD-R DL discs correctly and ImgBurn is the only burner I know of that can do ti correctly. DVD-R DL discs are insanely expensive so you really need an excellent reason for using them. DVD+R DL are not only significantly cheaper, they are much easier to burn and offer somewhat better compatibility with DVD players in my experience.
"somewhat better" is an understatement.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
LOL! You may be right. My experience is too limited to draw any definite conclusions, but I can say that most of my DVD players had big problems with -R DL media. My newest ones did not though.Originally Posted by lordsmurf
DVD Lab Pro Audio Problems
By Outcast212 in forum Newbie / General discussionsReplies: 6Last Post: 21st Feb 2009, 02:11 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 01:12 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 12:22 -
DVD Authoring with DVD LAB PRO doesnt create all files
By SSJ4Thiran in forum Authoring (DVD)Replies: 16Last Post: 18th Feb 2008, 10:03 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00
Statistics
Newest guides
Latest tool updates
New media comments
