VideoHelp.com Forum
Results 1 to 11 of 11
    A strange thing...
    The Freeware runs fine but the 3.0 PRO crashes every time i used to open a DVD-Folder.
    any suggestions???
    regards
    Zonediver
  2. Member Soopafresh's Avatar
    Right click on the executable and run it in XP compatibility mode
    "Quality is cool, but don't forget... Content is King!"
    Hi Soopafresh,
    thanks for your reply - i tried several settings (win XP SP2/3 and Vista SP1/2) but no way. As soon as i choose the DVD-Folder, the programm crashes - strange. I did also several reinstallations but without success.
    In the meanwile i got it work - dont know how - but Star Trek 11 hangs in Win7 MediaCenter at TimeIndex 1:10:15.
    Now i tried a Freeware called "XMedia Recode". This Software can also convert a DVD in a single MPEG-File
    without "re-encoding"
    And now, we have 3 funny things:
    1) its much faster then VOB2MPG PRO
    2) Star Trek 11 works fine now - very funny because V2M Pro cant still do this film
    3) it cost no money
    Shame on the programmers - i spent mony for nothing
    Setup.exe for VOB2MPG must be run in
    Compatibility Mode (XP SP2)
  6. Member ChrissyBoy's Avatar
    No you haven't. Send me an email and i'll refund you....
    I am running Windows 7 64-bit and am having the same problems. I haven't been able to select a VIDEO_TS folder from either a DVD drive or harddrive. I tried all the above suggestions:
    1 - Run setup.exe in Compatibility Mode XP SP2/3 as Administrator.
    2 - Run VOB2MPG.exe in Compatibility Mode XP SP2/3 as Administrator.
    What should I do now?
    Thanks.
    hotch
  8. Member ChrissyBoy's Avatar
    Thanks.
    Drop me an email and i will give you a new build to try - to see if it solves this issue for you.
    Thanks.
    I got the same problem on my machine Win 7 64.
    The standard version is running without any problems, but the pro version which I paid for is crashing when trying to open a dvd.
    Is there a solution for this?
  10. Member ChrissyBoy's Avatar
    If you email me i can send you a build which should solve this.
  11. Member JordonB's Avatar
    Loaded it normally on about 3 machines with 64bit win 7. Maybe you need a clean install.
  1. How do you get VCDeasy to work on Windows 7 Ultimate (32bit) ?
    By DragonLord721 in forum Newbie / General discussions
    Last Post: 24th Nov 2010, 09:44
  2. cannot install vob2mpeg pro
    By rodee728 in forum SVCD2DVD & VOB2MPG
    Last Post: 30th Mar 2010, 16:53
  3. Replies: 4
    Last Post: 26th Mar 2010, 15:13
  4. XP Pro 32bit Vs. 64bit ?
    By Noahtuck in forum Computer
    Last Post: 5th Aug 2009, 12:37
  5. Windows Vista - 32bit or 64bit?
    By HatchetMan in forum Computer
    Last Post: 12th Jan 2008, 00:24
