I have the Intensity Pro and along with it I bought another internal hard drive and it seems it's not quite what I need for this capture card as it barely matches the minimum speed for high def recording at 720p and a lot of the times I get a substantial amount of lost frames that make the video barely playable. I have also noticed that after running the speed test with some data on the hard drive, the results are worse so I always have to format the drive before a new recording, and I would not record more than 10 mins or it'll start dropping frames (sometimes it does it right away). I assume this would be a hard drive issue and so I'm looking to buy a more suitable hard drive for this capture card, any suggestions are appreciated.
Hard drive:
http://www.wdc.com/en/products/produ...sp?driveid=301
Intensity Pro speed test:
http://i13.photobucket.com/albums/a2.../speedtest.jpg
System Specs:
64bit Windows 7
Core 2 Quad Q8300
2x 512GB HD - 4GB RAM
For uncompressed 720p you need two hard drives in RAID zero. For uncompressed 1080i you need three drives in RAID zero. These would be separate from your OS drive C:.
Or you can use the BlackMagic MJPEG codec to compress on-the-fly to a single drive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I was way off trying to record uncompressed video. I will now use it compressed. It seems to work a lot better. Thanks for your response.Originally Posted by edDV
Black Magic Intensity Shuttle or Intensity Pro?
By perasbro in forum CapturingReplies: 3Last Post: 12th Oct 2011, 17:56 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42
Statistics
Newest guides
Latest tool updates
New media comments
