I am trying to convert the PGS subtitles to .srt on one of my BD rips, which I assume is a format that can be displayed by the WD TV. It does not display PGS subtitles, at least not for me.
I use tsMuxer to demux the video, audio and the subs from the BD. I then use SupRip to convert the PGS subs into srt. However, when I use tsMuxer again to mux the video, audio and the srt subs to an M2TS container, tsMuxer converts the srt subs back onto PGS. Is there a way to have tsMuxer keep the srt format?
I don't think think the m2ts supports srt subtitles...
Doesn't the wdtv support external srt subtitles? Or maybe srt in mkvs.
It may indeed be the case that m2ts does not support srt subs. How would I use external subtitles?
Got it working. Placed the M2TS file containing the muxed video and audio without subtitles, along with a separate srt subtitle file into the same folder, and the WD TV plays the subs correctly now.
It's a bit of a chore converting the subs to srt with SupRip, as a lot of the characters have to be entered manually. Otherwise it works well.
De-muxing and finding an extra subtitle with Tsmuxer
By cal_tony in forum SubtitleReplies: 2Last Post: 23rd Aug 2011, 10:56 -
Problem with PGS to SRT.
By Zangetsu in forum SubtitleReplies: 7Last Post: 15th Jul 2010, 21:08 -
Demuxing PGS Subtitles
By ematthys in forum SubtitleReplies: 2Last Post: 11th Dec 2009, 13:29 -
MKV avc to m2ts via tsMuxer;1080p muxing problem for ps3. Please
By rafoolik in forum Blu-ray RippingReplies: 5Last Post: 11th Aug 2009, 17:55 -
.SRT to .SUP (PGS Blu-ray/AVCHD format)
By Coolice in forum SubtitleReplies: 5Last Post: 21st Feb 2009, 18:07
Statistics
Newest guides
Latest tool updates
New media comments
