VideoHelp.com Forum
Results 1 to 26 of 26
    hi
    Just purchased a new Sony/NEC USB external Blu-ray player for my mac/pc (s) / network ($50 so I had to).
    Works fine after finding the right software for my PC.
    Am I right that there is no blu-ray 'playing' software for a MAC and the only way at the moment to play blu-ray on a mac, is this old thing called ripping.
    I did not think I was that far ahead of the curve on the pc.
    The mac of course sees the blu-ray unit.
    Thanks in advance
  2. Hope it can burn dvds and cds. If not your SOL and makemkv will not be able to rip blurays on your mac.
    www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac
    Toast will burn BluRay. LaCie ships it with their burner so it should work with your burner, as well.
    Playing it back, however, ...???
  4. Mac does not support BD playback at this time.
  5. I believe on Mac you can use Makemkv to play Bluray discs as of version 1.4.9
    http://www.makemkv.com/forum2/viewtopic.php?f=1&t=703
    Direct video streaming
    Postby mike admin » Fri Dec 04, 2009 8:14 am
    Starting from version 1.4.9 MakeMKV supports direct video streaming. Currently this feature is highly experimental. Direct streaming enables instant playback of blu-ray and DVD discs without converting them to MKV first - while less interesting for DVD it is quite usable for blu-ray since it enables blu-ray playback on Linux and Mac OS X directly from optical disc
  6. yep MakeMKV works just great for a bluray player for Mac. I believe it's the first bluray player for Mac (could be wrong though). True doesn't do menus or anything like that but you can watch main movie or even extras that you leave out of your bluray rips.
    Open bluray disc in Makemkv and then click Stream.
    Click http://192.168.0.180:51000 (for instance) to open your default web browser.
    It'll look something like this
    name	value
    type	Blu-ray disc
    name	V For Vendetta
    titlecount	10
    title0	/web/title0
    title1	/web/title1
    title2	/web/title2
    title3	/web/title3
    title4	/web/title4
    title5	/web/title5
    title6	/web/title6
    title7	/web/title7
    title8	/web/title8
    title9	/web/title9
    navigate to title look at duration of title like
    name	value
    id	0
    duration	2:12:32
    chaptercount	32
    formatcount	2
    format0	m2ts
    file0	/stream/title0.m2ts
    format1	ts
    file1	/stream/title0.ts
    then right click and copy title
    http://192.168.0.180:51000/stream/title0.ts
    Then paste that link in VLC in the File | Open Network (command N) in the URL section and voila watch your bluray on Mac directly off the bluray disc in VLC.
    Do not try to stream or play in Firefox or Safari it just won't work.
    So far no official blu-ray playing software, work arounds yes, but a bit of a hassle. So the answer is no, not like the pc has with all their software players. Its a shame, it'd be nice to add to my mac.
    Good luck,
    Ted
    Talk nerdy to me
  8. Originally Posted by mrbass View Post
    name	value
    type	Blu-ray disc
    name	V For Vendetta
    titlecount	10
    title0	/web/title0
    title1	/web/title1
    title2	/web/title2
    title3	/web/title3
    title4	/web/title4
    title5	/web/title5
    title6	/web/title6
    title7	/web/title7
    title8	/web/title8
    title9	/web/title9
    name	value
    id	0
    duration	2:12:32
    chaptercount	32
    formatcount	2
    format0	m2ts
    format1	ts
    The "Stream" button is disabled after opening the external bluray disk.
    name	value
    type	Blu-ray disc
    name	V For Vendetta
    titlecount	10
    title0	/web/title0
    title1	/web/title1
    title2	/web/title2
    title3	/web/title3
    title4	/web/title4
    title5	/web/title5
    title6	/web/title6
    title7	/web/title7
    title8	/web/title8
    title9	/web/title9
    name	value
    id	0
    duration	2:12:32
    chaptercount	32
    formatcount	2
    format0	m2ts
    format1	ts
    You need to select backup and an wait until makemkv has identified the content on the BD. Once the app will be done your stream button will be available. You will see a list of checkboxes. Uncheck all, but the one corresponding to the largest file (that's the movie). Select stream and then follow the info provided above, but keep in mind that's an experimental feature and may not work with all BD titles. Good luck!
  10. Hello guys,
    Are there some software blu-ray player available for Mac already?
    I've found these recent blu-ray player reviews http://www.reviewmaze.com/2011/01/wi...-software.html and there is good info but nothing mentioned about Macs. Do you know if any of those applications could be used also for Mac computers?
    I hope there is something I can use for playing blu-ray discs.
    Thanks in advance!
    There's no easy way to Blu-Ray movies on mac. That's sad, but I found a work around.
    Use MakeMKV Beta to create a Streaming Server with your Blu-Ray discs to do that I had follow the Steps describe at this web site:
    Ultimate Mac Upgrades
    STEP 1- Open MakeMKV and put a Blu-Ray disc in your drive.
    STEP 2- In the Toolbar select File>Open disc> and select your Blu-Ray drive.
    STEP 3- Start Streaming the Blu-Ray. This action create a local streaming server that we can access by VLC.
    follow the link you'll find in MakeMKV
    You should see a message saying : "This page is designed to be read by robots, not humans..." at the last line you should see the link /web/titles
    STEP 4- Open /web/titles link.
    STEP 5- Open the main movie title link. You'll find the length of the movie when you'll click on the link, that way you can be sure you have the right title.
    STEP 6- Find the link with the extension ".m2ts", right click on this link and copy the link.
    STEP 7- Open VLC
    STEP 8- In VLC toolbar select File>Open Network (shortcut cmd+N).
    STEP 9- Paste the link in the URL space and hit Open. (It should look something like "http://192.168.2.1:51000/strem/[the movie title].m2ts"
    Done ! You can enjoy a full length Blu-Ray movie on Your Mac without ripping it !!
  12. Mod Neophyte Super Moderator redwudz's Avatar
    The problem is the decryption. If you could decrypt the BD like AnyDVD or similar does with a PC, the individual video files can be played back with VLC Mac or maybe other software players that can handle HD .m2ts files. Most times the largest .m2ts file is the main movie.
    For PC users, it's also mostly limited to programs like TMT3 or PowerDVD or similar for computer playback of a full BD disc. The movie industry doesn't appear to like playback on computers.
    I think digital distribution is trully the future of HD on Personnal computers.
    This is all pretty crazy just to play a Blu-ray disc in a Mac. Until Apple takes this media seriously and includes a full featured Blu-ray disc and media player, I suggest you install Windows in Boot Camp and then install Cyberlink PowerDVD 9 or above to play your Blu-ray disc. If you want to play a Blu-ray movie on your HDD or SSD, I suggest extracting the Blu-ray movie as an ISO file and mount it in a virtual drive for playback in PowerDVD. That's all you need to play your Blu-ray on your Mac.
    Blu-ray - the answer to a question nobody asked.
    Apple will not "take this media seriously" because it's a bad joke.
    Hmm, an interesting perspective. I take it you don't like Blu-ray??? Too bad, it really is a lovely cinematic experience! I'm not sure how it can be a "bad joke" as it is a cutting edge technology that submerges the audience in a truly rich audio and video environment. Perhaps you don't like the cost of BD discs or the large file size, e.g., BD25 takes about 30 GB of space? In any event, the technology is here and it's not going to vanish simply because Apple OS X has not adopted it.
    I have a 720p TV and the OTA broadcast stations are plenty sharp. When I watch movies, I prefer to let the director use his (internal) vision to provide the "cinematic experience" rather than being forced to provide excruciatingly detailed images that, perhaps, detract from the atmosphere (s)he is trying to attain.
    The cost is, indeed, horrible but I'm not talking about $$; rather, it's the draconian DRM that is the real purpose of the medium. HDCP over HDMI or you get 480p. Hollywood's adoption of Blu-ray is for no other reason that that. The technology will vanish although there will be those who, like their spiritual forebears, will hold on to their Betamax VCRs and pound sand complaining.
  18. Member
    [QUOTE=rumplestiltskin;2075695][QUOTE=daodeltaforce;2075669]
    Well, I do agree that DRM is the name of the game for the motion picture industry, but that's the nature of the business. Artists need to protect their creative interests. If you want to bypass DRM you can simply decrypt the disc using any number of software programs or download it from any number of websites. Voila! The Internet is free once again. I disagree about Blu-ray technology fading into the sunset, it is a wonderful cinematic experience, and is not akin to Betamax which did not even have DRM issues back in those days gone by. If you haven't set your Mac to output to 1080p on your big screen HDTV you are missing a really great experience.
    That Macgo Blu-ray Player is incredible. Does the best job I've seen with my LG Blu-ray player/ writer
  20. Member hazard0us's Avatar
    I tried this player with the Sony BDX-S600U on my wife's Late 2010 11" Macbook Air. At first glance the software works great, but it seems the Mac isn't powerful enough to play the movies... the sound is fine but the picture is herky-jerky. Jury's still out on that, got to do some tweaking. (I have an HP DM1z which plays the movies out of that Sony unit just fine)
    The software seems like a great product! Although at $49 it is a tad expensive.
    A picture is worth a thousand words, but a good camera is worth about a thousand bucks.
  22. The reason I'm here searching in vain for a solution is because MacGo's Mac Blu-ray Player will not work on any Mac I have tried it on. Same problem every time, it begins playback, identifies the disc and then hangs. Definitely try before you buy. On their FB page, lots of complaints from peeps who bought, software will not work, and have NO response from MacGo. One look at their site and you get the sense that nobody's home. Poor grammar as well as no certification or accreditation as to their customer service responsibilities = probably a site from who-knows-where and BUYER BEWARE!!
    There is NO GOOD REASON for an apple computer to NOT play a BD. Just none at all. It's BS. In January 2012, you can't play a BD on a Mac. What?!!
    Makes it kinda hard to set up Blu-ray functionality for my client's Mac mini AV Server. You can get a nice budget BD drive from OWS for about $99. But then you're stuck because there is no working software to enable the viewing of the BD disc. www.macblurayplayer.com does not work as advertised. VLC says their player can play Blu-ray, but their is no provision or procedure to enable this.
    Arrgghhh! Very frustrating. Only way I've found to get good results is to rip via MakeMKV (great software) and then play in your server software of choice, VLC, PLEX, XBMC, etc. Thanks to MRBASS and others for the streaming help. It does work but I noticed the movie pauses when the disc must spin-up once the buffer calls for more.
  23. Member
    If you read the review here: http://www.tomshardware.com/forum/835-69-macgo-player you get the feeling that the MacGo thing is a scam. I'd recommend you go here: http://eshop.macsales.com/search/external+blu+ray as OWC is a quality vendor and stands behind the products they sell.
  24. Member
    You are right about VLC. I went to their main webpage and they do claim to play BluRay discs. That's BS. They have NEVER supported what any rational person would consider to be playback. Namely they have never supported BluRay menus. Sure if you burn MKV files to a BluRay disc, they will play that (assuming for some reason that meets your definition of "plays BluRay discs" - get it, not BluRay FORMAT but the discs themselves), and if you try to play decrypted M2TS files directly under file play mode it should do that, but wow, this is really very misleading.
  25. Just learned something. First disc I tried was "Jarhead" BD. For some reason it hangs the software (on 3 different machines). Just got the Porcupine Tree "Anesthetize" BD concert in today and IT PLAYS!!!!!!!!!!
    So, MacGo's got a problem when a BD is too new (?) and the copy protection scheme is not yet known, I'm guessing?
    Whatever the case, the hang is a real bad deal because you must force-quit and then restart the computer – some "lib" file has the BD disc in its grasp and won't allow an eject.
    My workaround in a case of a BD like this, is to rip it to HDD with MakeMKV, then watch on VLC.
  1. Blu-Ray Player that plays .avi (and other) with external hard drive?
    By RushMaster in forum DVD & Blu-ray Players
    Last Post: 26th Dec 2011, 11:51
  2. Best blu ray ripping software for Mac?
    By FuzzyReets in forum Blu-ray Ripping
    Last Post: 5th Sep 2011, 21:53
  3. Replies: 32
    Last Post: 28th Jun 2011, 15:21
  4. Best Software Player for Blu-Ray Playback
    By jet757f in forum Software Playing
    Last Post: 5th Aug 2010, 21:58
  5. Replies: 2
    Last Post: 20th Jan 2010, 11:50
