Hi all,
I've just bought a DVD player (Sony DVP-NS710) in USA (region 1) and I need to convert it in All Regions (or at least Region 4).
Anybody knows the code required to hack it?
Thanks a lot!!!!!
Thread: Hack Code for Sony DVP-NS710
Did you "Google" the player before you bought it to see if it can be hacked?
You can always ask and maybe you will be lucky and someone will respond with a code. It doesn't happen much, but maybe 5% of the time or so it happens. However, you do need to know that currently Sony and Samsung players are the most difficult to unlock in the world and very few can be unlocked. Unlocking a Sony, if a code even exists (usually it doesn't), usually requires you to purchase and use a special, expensive remote control. Even if you purchase the remote, I can't guarantee you that the code will work.
You can thank Hollywood for this as they have put a lot of pressure on manufacturers to stop making players that can be made region free and Sony, also being a content maker, has been quite happy to go along with this. Sony's DVD players have always been consumer unfriendly. They're hard to unlock, they often didn't support such "exotic" formats as VCD and SVCD, at one time they refused to play anything on CD-R unless you happened to be lucky enough to use one of the very few brands that they would play and so on. If I was going to buy a DVD player, Sony would be my very last choice and I'd have to have it given to me for free before I'd think about using it.
Hi,
I Bought this DVD too, and I need the unlock code. Anybody found it?
I made a lot of searches on internet but nothing!!
Is there any chance that the code never be discoved???
Someone post this recently. It does not work for my region-1 DVD. Please try and let me know if you can make it works.
http://www.videohelp.com/dvdhacks?dv...=ns710&hits=50
MAKOTO DVP-823 - need code free hack help
By HowardNeedsHelp in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Mar 2011, 14:58 -
Hack code for Sony DVP FX930 portable DVD player
By lgaak in forum Portable VideoReplies: 18Last Post: 28th Aug 2010, 15:03 -
Region Code Hack for Philips DVP 3005
By luelma in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Aug 2009, 11:17 -
Region code on Sony DVP- NS315?
By LilMac in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Aug 2009, 10:16 -
Sony DVP-FX820 hacking code
By SiggiJo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st May 2008, 08:59
