VideoHelp.com Forum
    I used to burn CDs and DVDs fine; but suddenly, I can't burn CDs OR DVDs anymore. I tried using NERO, DVDDecrypter, and Cheetah. But they all won't work for me.
    Whenever I try to burn on NERO, it would say:
    Could not perform end of Disc-at-once.
    Does anyone know what's the exact problem here? Please help.
    I have the log from NERO if that'll help:
    Windows Vista 6.0
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 9.0.9.100
    Internal Version: 9, 0, 9, 100
    (Nero Express)
    Recorder: <HL-DT-ST DVDRAM GSA-T50F>Version: TT04 - HA 1 TA 0 - 9.0.9.100
    Adapter driver: <Serial ATA> HA 1
    Drive buffer : 2048kB
    Bus Type : default
    CD-ROM: <HL-DT-ST DVDRAM GSA-T50F >Version: TT04 - HA 1 TA 0 - 9.0.9.100
    === Scsi-Device-Map ===
    DiskPeripheral : Hitachi HTS543232L9SA00 iaStor Port 0 ID 0 DMA: On
    CdRomPeripheral : HL-DT-ST DVDRAM GSA-T50F iaStor Port 0 ID 1 DMA: Off
    === CDRom-Device-Map ===
    HL-DT-ST DVDRAM GSA-T50F D: CdRom0
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 2047MB (2097151kB)
    Free physical memory: 1427MB (1461912kB)
    Memory in use : 51 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    11.12.2009
    UDF compilation
    10:04:40 PM #1 Text 0 File SCSIPTICommands.cpp, Line 450
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    10:04:40 PM #2 Text 0 File Isodoc.cpp, Line 6789
    UDF document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    UDF Mode : pure
    UDF Options : automatic
    UDF Revision : 1.02
    UDF Partition Type : physical
    10:04:40 PM #3 Text 0 File Burncd.cpp, Line 3563
    Turn on Disc-At-Once, using DVD media
    10:04:40 PM #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
    FS Settings: using validator 'CUDFSettingsValidatorDVD'
    ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
    Changing UDF revision from '1.02' to '1.02'
    10:04:40 PM #5 Text 0 File DlgWaitCD.cpp, Line 312
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2205023 (490:00.23, 4306MB)
    10:04:40 PM #6 Text 0 File DlgWaitCD.cpp, Line 324
    Write in overburning mode: NO (enabled: CD)
    10:04:40 PM #7 Text 0 File DlgWaitCD.cpp, Line 2951
    Recorder: HL-DT-ST DVDRAM GSA-T50F, Media type: DVD-R
    Disc Manufacturer ID: <UME02> <>
    Disc Application Code: 64, Disc Physical Code: 193
    10:04:40 PM #8 Text 0 File DlgWaitCD.cpp, Line 499
    >>> Protocol of DlgWaitCD activities: <<<
    10:04:40 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 756
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2205024 (2205024) = #2205024/490:0.24
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2205024 blocks [D: HL-DT-ST DVDRAM GSA-T50F]
    10:04:40 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 958
    Prepare [D: HL-DT-ST DVDRAM GSA-T50F] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4515889152, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 2205024 | 0 | 0x00
    2205024 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    10:04:40 PM #11 Text 0 File SCSIPTICommands.cpp, Line 240
    SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
    10:04:40 PM #12 Text 0 File Burncd.cpp, Line 4362
    Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
    10:04:40 PM #13 Phase 24 File dlgbrnst.cpp, Line 1767
    Caching of files started
    10:04:40 PM #14 Text 0 File Burncd.cpp, Line 4484
    Cache writing successful.
    10:04:40 PM #15 Phase 25 File dlgbrnst.cpp, Line 1767
    Caching of files completed
    10:04:40 PM #16 Phase 36 File dlgbrnst.cpp, Line 1767
    Burn process started at 8x (11,080 KB/s)
    10:04:41 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2675
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    10:04:41 PM #18 Text 0 File DVDR.cpp, Line 3259
    Recording mode: Sequential Recording Mode
    10:04:41 PM #19 Text 0 File DVDR.cpp, Line 3413
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    10:04:41 PM #20 Text 0 File Cdrdrv.cpp, Line 10187
    ---- Disc Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
    Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    Outer Limit of Data Recordable Area: 26127F h
    Data in Burst Cutting Area (BCA) does not exist
    Revision number of maximum recording speed: 6.0
    Revision number of minimum recording speed: -
    Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
    Class: 0, Extended part version: 33
    Start PSN of the Extra Border Zone: 2FE10 h
    Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
    Media Specific [16..783]:
    00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
    00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    01 40 C1 FD 9E D8 52 00 - 02 84 0D 11 66 78 90 00 .@....R.....fx..
    03 55 4D 45 30 32 00 00 - 04 00 00 00 00 00 00 00 .UME02..........
    05 A8 82 00 20 00 02 00 - 06 09 09 15 A9 9A 90 00 ................
    07 88 80 00 00 00 00 00 - 08 07 11 0C 10 0B 06 00 ................
    09 95 07 0D 0B 68 88 00 - 0A 80 00 00 00 00 10 00 .....h..........
    0B 08 16 17 96 88 85 00 - 0C B7 89 33 83 30 33 00 ...........3.03.
    0D 00 00 D0 00 00 00 00 - 0E 0B 1E 39 33 29 20 00 ...........93)..
    0F 50 21 2F 19 97 B5 00 - 10 88 80 00 00 00 00 00 .P!/............
    11 00 00 00 00 00 00 00 - 12 0B 29 39 35 29 20 00 ..........)95)..
    13 50 23 2F 19 97 B5 00 - 14 88 80 00 00 00 00 00 .P#/............
    15 00 00 00 00 00 00 00 - 16 09 3F 3C 38 27 1B 00 ..........?<8'..
    17 60 1A 25 0F 7A B5 00 - 18 88 80 00 00 00 00 00 .`.%.z..........
    19 00 00 00 00 00 00 00 - 1A 0B 4D 41 37 29 23 00 ..........MA7)#.
    1B 50 21 31 17 B9 00 00 - 1C 00 00 00 00 00 00 00 .P!1............
    10:04:41 PM #21 Text 0 File DVDR.cpp, Line 3551
    Reserved Track size: 2205024 (21A560h, 4306MB) -> return code 0
    10:04:41 PM #22 Text 0 File ThreadedTransfer.cpp, Line 273
    Pipe memory size 83836800
    10:04:41 PM #23 Text 0 File CUDFTransferItem2.cpp, Line 660
    GenUDF2 FS Layout:
    Sectors to be written: 2205024
    Session Start: Sector 0
    Volume Structure: Sector [0, 256] (257 Sectors)
    Meta Data: Sector [257, 284] (28 Sectors)
    Data: Sector [285, 2204721] (2204437 Sectors)
    After Data: Sector [2204722, 2204735] (14 Sectors)
    Trailer Track: Sector [2204736, 2205023] (288 Sectors)
    GenUDF2 Parameters:
    PrepTime: 12-11-2009 22:04:40
    UDF Revision: 1.02
    UDF Partition Type: Physical
    UDF Special Mode: None
    Bytes per Sector: 2048
    Session Start: 0
    Physical Partition Start: -1
    Total Capacity: 2298496
    Multi Session Mode: None
    Disc Type: DVD-R
    OS Class: 0
    Volume ID: My Disc
    Allow Unicode Labels: 0
    Duplicate Meta Data: 1
    MS Info File: 00000000
    VMS Rollback File: 00000000
    Create ISO bridge: 0
    ECC Block Length: 16
    Sparing Packet Length: 32
    Allocation Unit Size: 32
    Alignment Unit Size: 16
    Make Writable: 0
    Access Type: Read-only
    10:04:52 PM #24 SPTI -1135 File SCSIPassThrough.cpp, Line 215
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
    CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    Sense Area: 0x70 00 03 00 00 00 00 0A 32 4D 03 0C 0C
    Buffer x190b0040: Len x10000
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    10:04:52 PM #25 CDR -1135 File Writer.cpp, Line 306
    Write error
    10:04:52 PM #26 Text 0 File DVDR.cpp, Line 3819
    EndDAO: Last written address was -1 (FFFFFFFFh)
    10:04:52 PM #27 CDR -1135 File WriterStatus.cpp, Line 292
    Write error
    10:04:52 PM #28 TRANSFER -24 File WriterStatus.cpp, Line 292
    10:04:52 PM #29 Text 0 File DVDPlusDualLayer.cpp, Line 1424
    SetDriveCaps: Set LAST LBA of layer 1 to 0
    10:04:52 PM #30 Phase 38 File dlgbrnst.cpp, Line 1767
    Burn process failed at 8x (11,080 KB/s)
    10:04:52 PM #31 Text 0 File SCSIPTICommands.cpp, Line 287
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    10:04:55 PM #32 Text 0 File Cdrdrv.cpp, Line 11444
    DriveLocker: UnLockVolume completed
    10:04:55 PM #33 Text 0 File SCSIPTICommands.cpp, Line 450
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
    pos
    crap discs
  3. Member victoriabears's Avatar
    Could be the burner, how old is it and how many discs have you burnt, as previous poster said though, could be the media, have you changed what you are using?
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    I've had it since May 2009. So only 6 months? I burn occasionally and they all worked fine until now. I have tried a Memorex DVD, and that didn't work either. :/
  5. aBigMeanie aedipuss's Avatar
    there aren't any worse media than ume. get some verbatim or taiyo yuden(not "value line").
    memorex are not much better.
    only use imgburn for all media burning.
    So the problem's with the DVD and nothing else??
    you won't believe me until you try some verbatim or taiyo yuden, but most likely yes. the error is a simple write error, the drive can't write to a sector of the disc because it's most likely a bad disc.
  8. Member hech54's Avatar
    Nero and junk discs.....a deadly combination.
  1. firmware burning problem
    By weedhopper in forum DVD & Blu-ray Players
    Last Post: 1st Aug 2010, 11:34
  2. BDMV burning problem
    By rickoshay in forum Authoring (Blu-ray)
    Last Post: 12th Jun 2010, 04:48
  3. Convertxtodvd burning problem
    By kulkul in forum Newbie / General discussions
    Last Post: 3rd Jun 2009, 20:24
  4. Problem burning data DVD using Nero 6 burning rom
    By thebluekey_17 in forum Newbie / General discussions
    Last Post: 19th Feb 2009, 13:14
  5. Burning tracking problem or software problem???
    By yogart in forum Authoring (DVD)
    Last Post: 24th May 2007, 12:39
