An LCD TV and home theater system provide the digital optical or digital coaxial cord connection. What cord connection is better for the audio and what is the difference between two connections? Thanks for the answer.
They both produce equal signal spec (SPDIF). Small differences,
Coax is cheaper especially for long cables. Standard video coax can be used.
Optical provides electrical isolation eliminating chance of ground loop hum.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
no difference. the same signal goes over either.
Yep no difference. At least none that I've been able to tell. I have most of my equipment connected by fiberoptic but sometimes I use coax because that is the only option on the given hardware. They both produce digital sound (surround sound if its encoded that way).
I would take eddv's recommendation into consideration if the length of the cable is going to be an issue.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Scanned 16mm Optical Soundtrack Direct to Digital Audio?
By mtt1853 in forum AudioReplies: 25Last Post: 14th Sep 2011, 07:03 -
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 21st Dec 2009, 15:00 -
Digital Optical Out
By acid_burn in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Feb 2008, 23:25 -
Digital optical cables
By tj1182 in forum DVB / HDTVReplies: 3Last Post: 24th Feb 2008, 12:55 -
If I buy a 14 inch SDTV with a digital tuner, can i watch digital programs
By davidsama in forum DVB / HDTVReplies: 3Last Post: 6th Sep 2007, 10:25
Statistics
Newest guides
Latest tool updates
New media comments
