    Alright, I am sorry to touch a topic lots of people apparently have had problems with before. But all the topics I found were about muxing it to an mp4 file or something like that.
    I do not care about remuxing it, nor about the audio. All I want to do is to remove the subs WITHOUT conversion, so I can play the seperate .mkv files in Final Cut. I have experienced that I can play textless mkvs perfectly fine in FC so I figured it is simply due to the subs that I can't use them.
    Anyway, I have been looking around on the internet but wasn't really successful. I found a hint to use imkvextract but when I downloaded it it wouldn't work. Not sure if it is because it works only on ppc (I have an Intel Macbook OS 10.4.2) or (I am assuming that) I am actually missing a program or something to make that work lol
    Anyway, I really beg for your help, I used to convert my mkv's using avidemux to lossless Huffies, but my external Harddrive is STUFFED; so I need to find another option. Please, help me. For everything that includes using the terminal:
    I am a bit... helpless in that aspect, so please, please explain carefully.
    Thank you very much!
  2. VH Wanderer Ai Haibara's Avatar
    Do you have Rosetta installed? If you do, you can use PPC-only apps.
  3. Explorer Case's Avatar
    You could try MKVToolnix (it has a Mac GUI app in the "second package", which installs as MkvMerge.app) to de-select and remove any stream that you don't want, and re-save the file as .mkv.
    WOW, this was awfully easy lol Thank you so much, no problems at all it worked perfectly!!
    @AiHaibara: No, I don't have Rosetta installed, but thank you as well.
  5. Member porfitron's Avatar
    Also, if you ever want to just completely demux an MKV on Mac, I use iMkvExtract, which is just a Mac GUI for MkvExtract:
    http://imkvextract.mac.findmysoft.com/
    It'll output the .h264, .aac, .srt and other attachments in case you want to do any individual edit on just one attachment (e.g. boost audio before a re-mux).
    You'll find me at:
    DivX Labs and the DivX Developer Portal
    Follow us on Twitter: @DivXLabs
  1. Replies: 1
    Last Post: 9th Apr 2009, 14:58
  2. matroska files playing problems
    By pepevideo in forum Blu-ray Ripping
    Last Post: 30th May 2008, 09:28
  3. Another conundrum! How to burn Matroska HD files to DVD-R?
    By expat in forum Newbie / General discussions
    Last Post: 28th Sep 2007, 15:02
  4. Can't play MKV (Matroska) files
    By ambrosechapel in forum Mac
    Last Post: 5th Sep 2006, 20:35
  5. Replies: 10
    Last Post: 14th Nov 2004, 08:52
About   Advertise   Forum   RSS Feeds   Statistics   Tools
