VideoHelp.com Forum
    Hi,
    Just formatted my computer and reinstalled Ulead and having a problem. Some of my MP3 files, which I use for background music, are coming up "file format mismatch" and some work fine. All the MP3 files are the same format/bit rate. Not sure why only certain ones don't work. As for the ones that work, I can't play them in the authoring, what I mean is if I try to listen to the MP3 file to set a start/end spot on the file it only plays the first second or so and then stops. Not sure why that is either. Do I need a codec or something. It never did these things before the format. Help please!!!!
    I'd guess it's a codec issue. Maybe you should run Windows Updates via going to the website via Internet Explorer and download all the codecs. Another thing I could think of is turning off your anti-virus when installing programs or running windows updates. These are just guesses.
  1. Ulead DVD Movie Factory 6 Plus
    By orientaldragon in forum Newbie / General discussions
    Last Post: 2nd Apr 2011, 08:48
  2. Ulead DVD Movie Factory 6 Plus
    By Ragamuffin in forum Authoring (DVD)
    Last Post: 6th Oct 2009, 12:22
  3. DVD Audio format mismatch?
    By Scally in forum Authoring (DVD)
    Last Post: 17th Jan 2008, 08:07
  4. Ulead DVD Movie Factory
    By koberulz in forum Newbie / General discussions
    Last Post: 26th Jun 2007, 07:14
  5. Ulead DVD Movie Factory 5 Plus Help
    By sootylfc in forum Authoring (DVD)
    Last Post: 21st May 2007, 18:20
