I downloaded and installed the Windows demo of the latest version of Cineform Neo Scene. Unfortunately every time I try to start it I get a windows error:
"HDlink.exe has stopped working"
I'm using Vista 32 bit, with 4gb ram, core 2 duo and decent enough graphics card. But like I say I cant even open the program to try and convert anything.
Any ideas what this could be? Do I need anything else installed or would somethign be conflicting with it? (AC3 is installed ok)
Results 1 to 11 of 11
Thread: Cineform Neo Scene problem
I still am getting this error and have found no way to resolve it.
Is there any other intermediate codec converters out there which are virtually lossless - so I could convert AVCHD so I can edit it on my PC (in premiere pro).
I was hoping to try this cineform but have no had any luck getting it to work.
Have you tried run in winxp compatibility mode? right click neoscene and choose windows xp under compatibility.
Or maybe export the avchd to Avid DNxHD in for example quicktime pro.
Thanks Baldrick will give that a try later and see.
Sill didnt work - I tried to install and it kept failing, it said a progrma had prevented it from installing correctly.
I then ran it with XP compatibility and it install ok. But running the program after install doesnt work - even in XP mode
Any ideas why this is happening?
you might have to turn off all anti-virus/spyware/malware apps. neoscene runs a script at install. maybe even turn off uac and dep and run the install as admin on win7.
Hmm tried all that and it does install ok - but it just wont run no matter how I try to load it!
did you get the demo directly from cineform?
Yeah I got the demo from Neoscenen, they emailed a link to DL it. Might have to contact them to see if there is anyway to resolve this, strange one - maybe some software on my machine causing this?
i never got the demo to run here either, it said the time had expired or some such. i must have demoed a prior cineform product long ago.
I'd call or email Cineform support. They've always responded to my quaestions.
http://www.kiva.org/about
Cineform Neoscene and Prem Pro CS3.2 questions/Quest
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 33Last Post: 4th Sep 2011, 21:04 -
HD PVR and cineform neoscene
By Tahlos in forum Newbie / General discussionsReplies: 3Last Post: 19th Jun 2010, 22:11 -
Free alternativ for Cineform Neo Scene??
By Cazz in forum EditingReplies: 12Last Post: 11th Jul 2009, 19:05 -
Cineform Releases Neo Scene HDV and AVCHD Converter
By Soopafresh in forum Latest Video NewsReplies: 21Last Post: 7th May 2009, 18:06 -
AVCHD workflow with Cineform
By gazz1e in forum Video ConversionReplies: 0Last Post: 23rd Jan 2009, 03:24
