I've installed VOB2MPG PRO v3.0.0130 on a Windows 7 operating system, but when I try to run it I immediately get a message box saying "Finished processing. Duration (hh:mms): 00:00:00". The log file is as follows. Any thoughts on how to solve the problem?
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title: PRO
Version: 3.0.0130
Executable: C:\VOB2MPG PRO\VOB2MPG.exe
Executable size: 854 KB
Executable size in bytes: 874579
Executable CreationTime: 07/12/2009 14:20:04
Executable LastWriteTime: 11/12/2009 14:49:57
Executable LastAccessTime: 11/12/2009 14:49:57
****************************** Drives *******************************
Results 1 to 9 of 9
Can you take a look at
http://forum.videohelp.com/topic373834.html
and see if you also have a WMI issue. Can you try the System Info Tool in Accesories->System Tools to confirm?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for the suggestion, ChrissyBoy. WMI seems to be doing its job as it should, and I'm wondering whether there is any significance in the observation that the log files give the original Executable LastWriteTime and Executable LastAccessTime every time I run the programme?
By the way, I'm using a 64-bit version of Windows 7. Might that be at the root of the problem?
I run it on Win 7 64bit no problem.... What do you have for the Drives part of:
Make sure you are clicking on the VTS files within the disc not simply the title of the disc itself. Once you click on the VTS files (and you want to make sure you are in 'Vobset' mode first), then it will process all the way through. You might have known all this already, but if not... it might help.
I've got a whole load of drives, local and networked, so the list is quite long. Is there anything in particular I need to look out for?Originally Posted by ChrissyBoy
Drop me an email - i have a build you can try which should give us some more information.
Many thanks - will do.Originally Posted by ChrissyBoy
V3.0.0131 has fixed the problem. Many thanks to Chris.
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
I can't finish register process(VOB2MPG pro)
By xwestwood in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 8th May 2010, 12:35 -
Vob2Mpg Pro, Time doesn't match!!!
By DATENSCHUTZ1 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Apr 2010, 04:05 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
Help needed with VOB2MPG v3.0 - Pro. DVD doesn't look crisp from backup.
By marcos77 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Mar 2010, 09:27
