Hey guys,
I tried to backup some of my Blu-rays in MKV files. I Just want the orginal quality and the best german and english audio stream on it. With AC3 audio streams I have no problems but if the Blu-ray contains a DTS Master the sound stream I get is a Wave file. But when I mux the two wave audio streams I don't get a working MKV file. When I play the video with Media Player Classic I cant switch audio streams nor do I have a working audio stream.
Do I have to convert the wave in a DTS file? If thats the problem which program do I have to use to lose no quality?
Thread: Wave Files in MKVs
What tools are you using? tsmuxer, mkvtoolnix?
I think you can use eacto to convert to dts or ac3.
eac3to can also convert to FLAC.
I'm using Ripbot to get the video and audio stream. Then I mux it with MKVtoolnix. Is it not possible to have a wave audio stream in a mkv which is played correctly or is the mistake somewhere else?
When I converting the wave with eac3to am I losing quality then? Because my goal is to keep the original quality alive.
MKVToolNix supports DTS-MA now; perhaps you are using an older build? You can just re-wrap the original audio, no re-encoding
FLAC is a good alternative as suggested above; it's lossless, and you get a bit of compression to boot. It's also supported by more players, some don't support DTS-MA
mpg -> AC3 -> mono wave files.
By jocorok in forum Video ConversionReplies: 3Last Post: 24th Jul 2009, 02:15 -
how to link two wave files together: LPCM audio
By Modify_inc in forum Blu-ray RippingReplies: 8Last Post: 21st Jul 2009, 10:08 -
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 6Last Post: 6th Oct 2008, 21:59 -
Rip Only Certain Channels From Dolby 5.1 DVD to Wave Files?
By dvd-dude in forum AudioReplies: 5Last Post: 3rd Sep 2007, 22:07 -
Turning DVD chapters in to MP3 or wave files
By ericshogan in forum DVD RippingReplies: 7Last Post: 8th Aug 2007, 16:03
