Hi,I have had a problem with my recorder ever since the last digital re-tune on 2nd Dec.Previously I could pick up all terrestrial channels, and they would be numbered on my recorder, so I could record channels with ease.However,now the recorder does not pick up any digital channels, and I can only record digital channels through my t.v on the Av1 channel on the recorder, but if I change the input on my t.v from digital to anything else,the recording ends. Can anyone help? Will I have to buy a recorder with built in freeview to solve this problem?
Julie
I'm not in the UK nor have I ever used freview but I do own a EH-50 and a digital TV that outputs a video signal.
You will need to get a stand alone freeview box that you can run to your EH-50's Av1. The problem with using your TV's output is every time your turn it OFF, change channels or switch inputs it will effect the output to your Panny.
Panasonic DMR-EH50 and Pan. DVD-RAM disks inconsistent
By rehoboth in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2012, 21:50 -
Panasonic DMR-EH50, TVGOS gone, no data - can this be fixed?
By slugwump in forum DVD & Blu-ray RecordersReplies: 18Last Post: 1st Jan 2012, 12:11 -
Panasonic DMR EH50 - HDD Upgrade
By agdex in forum DVD & Blu-ray RecordersReplies: 1Last Post: 21st Jul 2011, 13:49 -
Panasonic DMR-EH50
By macapala in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2009, 08:35 -
Panasonic DMR-EZ27 and EZ28 switches channels while recording
By dtsb52 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2009, 11:59
Statistics
Newest guides
Latest tool updates
New media comments
