Tearing my hair out on this one. I have done this before with no problems. Using SVCD2DVD 2.5.5030 to convert AVI to DVD. Converted subtitles from .SRT to .SUP with Subtitle Creator 2.2. Absolutely, positively set Subtitle Creator to output NTSC subs (I've been burned by that before). Burned output of SVCD2DVD to DVD. Burnt DVD plays on the computer using PowerDVD and shows subtitles when I select them. Play DVD in same standalone player I have used for years, select subtitles on it, but don't get any subtitles. Verified problem is not likely the player by playing another movie created the same way a couple of months ago, using same version of SVCD2DVD and Subtitle Creator.
Anyone got a clue?
I'll attempt to tack my log file on here:
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="10/12/2009 10:19:35 PM" Filename="NONE">
<AssetSet>
<Asset ID="6598ad98-be0b-4c5c-bc6b-7d9e00334a9a" Path="Q:\DVDwork" Filename="2012.avi" />
</AssetSet>
<DVDStructure>
<TitleSet Name="2012" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="111" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">2012</MenuButton>
<Title Name="2012.avi" AssetID="6598ad98-be0b-4c5c-bc6b-7d9e00334a9a" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="D:\SVCD2DVD\Backgrounds\Lines _N_Reel.jpg" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="Q:\DVDwork" InitialDVDFolder="Q:\DVDwork" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="Q:\DVDwork" InitialMenuBackgroundFolder="D:\SVCD2DVD\Backgroun ds" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="D:\SVCD2DVD\Backgrounds\Li nes_N_Reel.jpg" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="True" SkipAC3="False" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="True" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="D:\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 1.36 GB
file=Q:\\DVDwork\\2012.avi
FormatName=avi
Num_Frames=227090
DurationInSecs=9084
Duration=02:31:23.6
VideoCodec=mpeg4
VideoFFSTNum=0
Width=640
Height=272
Standard=PAL
BitRate=1289
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
AVI2MPG: 3768kbs Full-D1
22:19:35: Looking for AVI PAR...
Pass 1/2: Processing 2012.avi
[2012] 22:19:37: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[2012] 22:19:37: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[2012] 22:19:37: libavutil 49.12. 0 / 49.12. 0
[2012] 22:19:37: libavcodec 52. 6. 0 / 52. 6. 0
[2012] 22:19:37: libavformat 52.23. 1 / 52.23. 1
[2012] 22:19:37: libavdevice 52. 1. 0 / 52. 1. 0
[2012] 22:19:37: libswscale 0. 6. 1 / 0. 6. 1
[2012] 22:19:37: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[2012] 22:19:37: Input #0, avi, from 'Q:\DVDwork\2012.avi':
[2012] 22:19:37: Duration: 02:31:23.64, start: 0.000000, bitrate: 1289 kb/s
[2012] 22:19:37: Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], 25.00 tb(r)
[2012] 22:19:37: Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 32 kb/s
[2012] 22:19:37: Output #0, dvd, to 'NUL':
[2012] 22:19:37: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, pass 1, 3768 kb/s, 25.00 tb(c)
[2012] 22:19:37: Stream #0.1: Audio: mp2, 48000 Hz, stereo, s16, 224 kb/s
[2012] 22:19:37: Stream mapping:
[2012] 22:19:37: Stream #0.0 -> #0.0
[2012] 22:19:37: Stream #0.1 -> #0.1
[2012] 22:19:37: [mpeg2video @ 0x1727e70]Using pulldown for PAL->NTSC.
[2012] 22:19:37: Press [q] to stop encoding
[2012] 22:34:43: [mp3 @ 0x1708640]mdb:34, lastbuf:8 skipping granule 0
[2012] 22:55:47: video:4174984kB audio:248339kB global headers:0kB muxing overhead 2.393285%
Pass 2/2: Processing 2012.avi
[2012] 22:56:09: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[2012] 22:56:09: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[2012] 22:56:09: libavutil 49.12. 0 / 49.12. 0
[2012] 22:56:09: libavcodec 52. 6. 0 / 52. 6. 0
[2012] 22:56:09: libavformat 52.23. 1 / 52.23. 1
[2012] 22:56:09: libavdevice 52. 1. 0 / 52. 1. 0
[2012] 22:56:09: libswscale 0. 6. 1 / 0. 6. 1
[2012] 22:56:09: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[2012] 22:56:09: Input #0, avi, from 'Q:\DVDwork\2012.avi':
[2012] 22:56:09: Duration: 02:31:23.64, start: 0.000000, bitrate: 1289 kb/s
[2012] 22:56:09: Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], 25.00 tb(r)
[2012] 22:56:09: Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 32 kb/s
[2012] 22:56:09: Output #0, dvd, to 'Q:\DVDwork\2012_S2D.mpg':
[2012] 22:56:09: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, pass 2, 3768 kb/s, 25.00 tb(c)
[2012] 22:56:09: Stream #0.1: Audio: mp2, 48000 Hz, stereo, s16, 224 kb/s
[2012] 22:56:09: Stream mapping:
[2012] 22:56:09: Stream #0.0 -> #0.0
[2012] 22:56:09: Stream #0.1 -> #0.1
[2012] 22:56:09: [mpeg2video @ 0x1727d00]Using pulldown for PAL->NTSC.
[2012] 22:56:09: Press [q] to stop encoding
[2012] 23:19:42: [mp3 @ 0x1708640]mdb:34, lastbuf:8 skipping granule 0
[2012] 23:42:21: video:4172460kB audio:248339kB global headers:0kB muxing overhead 2.453555%
23:42:22: Adding subtitle stream
23:47:02: SupMuxer: Done.
23:47:04: Done: Processing assets for DVD creation
Authoring DVD Folders
23:47:04: Creating TitleSet # 1
23:47:04: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
23:47:04: -->: DVDFolders creating VTS
23:47:04: -->: VTS 01
23:47:04:
DVD Folders: Processing Q:\DVDwork\2012_S2D.mpg...
23:51:10:
23:54:22:
23:54:22: Finalising DVD...
23:54:22: SVCD2DVD: DVDfolders
23:54:22: -->: DVDFolders creating table of contents
23:54:22: scanning Q:\DVDwork\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
23:54:22: Finalising DVD...Done
23:54:22: Done: Authoring DVD Folders
Results 1 to 1 of 1
Burned Video DVD Won't Play in Standalone Players
By adamwolf1965 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2009, 21:21 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
Media center video won't play on standalone dvd player
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2008, 22:04 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 01:21 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 21:15
