Years ago, I used Pinnacle, but I have not done any video since. It was work cam and software. I’ve never owned a video cam. I have a Canon HV30 on a brown truck as I type. I will play with Windows Movie Maker till the beginning of next month when I’ll have the $$ for software. On top of my list is Vegas Movie Studio 9 Platinum Pro Pack. It seems to be very popular, and I should be able to slide right into it since I’ve had experience editing videos. I only have two questions so far I just can’t seem to find info on, not that these questions will be a deal breaker.
1. I’ve seen the screen shot on their web site. The background is white. Is there an option to change it to gray?
2. Is it possible to rearrange the work space, so that the time lines are on the bottom?
Results 1 to 21 of 21
Gary
Will Fly for Food -
I just purchased this software and so far I'm loving it. I will see if I can figure out how to change the background color (if possible) and moving of the timelines. I'll get back to you if I can figure it out.
dbanimal -
Thanks. This is the software I will probably go with, as it seems to be the most popular in the forums, but I’m used to having the time lines on the bottom, and was just wondering if moving them is possible. I know it is with the Pro version, but not sure about Studio 9 Platinum Pro. Reading the specs here leads me to believe not, but still leaves a question.
And, of course if the white background can be changed to a shade of gray. Easier on the eyes.Gary
Will Fly for Food -
I've also been very happy with Vegas Movie Studio 9 Platinum Pro Pack. It's doesn't have all the features that the Pro version has and you do have the limited encoder, but the editor is great. I have also found that even though the encoder is limited, you can still save as DV, then open in DVD Architect and have it render a DVD at what ever rate you want. I think Movie Studio is limited to about 6000 bps, but I've done 9500 in DVD Architect. It meets my needs currently at a good price.
PS - I can move the timeline from bottom to top. Not sure about the colors. -
Excellent. Thanks for the info on moving the time line. I’m sure I’ll be happy with Vegas Movie Studio 9 Platinum Pro Pack. The screen shot of the program on their website shows the background as being an off white. It would be nice if it could be changed to a little darker gray, but moving the time line was more of a concern.
Gary
Will Fly for Food -
Have you tried downloading the evaluation copy? You can try before you buy.
Originally Posted by thomasjGary
Will Fly for Food -
I thought I heard that if you installed the evaluation version and then purchase the full package that it won't install correctly due to already having the eval installed. Be aware of this!!
The only things I've encountered so far is trying to load videos I recorded off my DVR in HD and in the .ts format. It won't load and closes Vegas. I'm wondering, do I need to convert it to mpeg before it will work or what?dbanimal -
Originally Posted by dbanimal
not true. the eval download is the full version and all it needs is the key/activation to turn on all features.--
Originally Posted by aedipussGary
Will Fly for Food -
OK, my bad. Some of the reviews said NOT to do the eval due to problems with the main install. I couldn't tell you based on experience.
dbanimal -
Does anyone know how long the Demo of Vegas lasts? I know the typical time for most software demos is 30 days, but there is zero info on the Vegas site on this, and I can not find the info by searching this site. I ask because I don’t want the demo to expire before I can afford to purchase it, which will be sometime after January 1.
Gary
Will Fly for Food -
I thought that Vegas Movie Studio 9 Platinum Pro Pack was just about all an enthusiast could want, this side of spending a fortune, but then I found that it doesn't even feature scopes/histograms?! *sigh*
http://www.sonycreativesoftware.com/moviestudiopp/compare -
Originally Posted by wingspar
Originally Posted by MJ Peg
I would like this along with the better encoder, but it's still a nice package. I don't have the money for the full version... -
Will Fly for Food -
Originally Posted by thomasjdbanimal
Would any of you happen to know the solution to my problem from this thread?
https://forum.videohelp.com/topic377167.htmldbanimal -
A new question. Figured I’d use my old thread again. I’ve been using the Demo of Vegas Movie Studio 9 Platinum Pro a little bit. I ordered the CD from Newegg, as it was considerably cheaper than ordering from Sony, and it should be here in two days. At the bottom of this page http://www.sonycreativesoftware.com/moviestudiopp, it says 1,001 Sound Effects is part of the package. I tried looking for these sound affects today, and could not find them. How does one find them?
Gary
Will Fly for Food -
there is vegas movie studio platinum and there is also the vegas movie studio platinum pro pack. the pro pack includes sound forge studio and the extras. the extras are not included in the demo, but should be on the cd.
Thanks. Nothing anywhere on the Sony site does it say the Demo is anything but the full version. The CD will be here tomorrow, so I’ll install the extras. Do you know if there is a way to just install the extras from the CD, and not have to reinstall the software, as I suspect the CD will be version 9.0, and my Demo is 9.0b (Build92).
Gary
Will Fly for Food
Vegas Movie Studio HD Platinum 10
By jjblackisback in forum SubtitleReplies: 3Last Post: 26th Apr 2011, 21:28 -
Vegas Movie Studio Platinum Pro Pack vs Adobe Premiere Elements 8
By bowmah in forum EditingReplies: 6Last Post: 27th Jan 2010, 21:15 -
Vegas Movie Studio 9 Platinum Pro Pack question
By dbanimal in forum EditingReplies: 8Last Post: 8th Jan 2010, 11:13 -
Vegas Pro and Movie Studio Platinum 9 bug (confirmed with Sony).
By The village idiot in forum EditingReplies: 7Last Post: 18th Dec 2009, 16:21 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 01:41
