Okay, I'm pretty new at this whole thing.
Ripped BD disc to hdd and so far every movie has contained one .m2ts file containing the entire film. Converted those to .mkv using Handbrake and no problems at all.
But now I've got a disc that ripped to hdd and there are dozens and dozens of .m2ts files and they don't seem to be in order of the movie.
?????? Do I need to combine them first??? or..?
I have no interest in retaining subtitles or multiple languages.
Thanks to all.
Results 1 to 10 of 10
Any ideas?
You can try tsMuxeR and combine all the parts together to a single file. I don't recall the name of the program, but you can read the playlist off the BD and figure out the order of the .m2ts files, then just mux them together. Maybe BDedit?
If you search around our site, there are a few threads with the same problem and they may give you more ideas.
And this thread would be better in our Blu-ray Ripping forum. Moving you.
Use instead ripbot264. It will fix it automatically for you.
eac3to works for determining main movie playlist tooOriginally Posted by Baldrick
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
BDinfo.Originally Posted by redwudz
Thanks for the help everyone.
I found ripbot264 did the job nicely.
One question: the output is a 3 gb file… coming from a 40 gb BD source… is that normal? Seems like quite a bit of conversion (i.e. quality loss).
The result looks very good, but not “blow your mind” good if that makes sense.
if you are not happy with quality so next time use CRF@20 or 18 . Lower value means larger file size / better quality
I use RipBot with two pass MKV and a output size of 8150MB. It looks very good on my 12' projector screen and it allows backup to DL DVD media, much better quality than the average commercial DVD. But it takes about 6hrs for the conversion. Just run it overnight.
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 7Last Post: 17th Mar 2010, 19:39 -
Combine multiple FLV files in one flow.
By nevsky in forum Video StreamingReplies: 0Last Post: 24th Jan 2009, 07:06 -
Combine mkv or m2ts files
By BDR in forum EditingReplies: 0Last Post: 25th Feb 2008, 04:31 -
Rip to HD... Multiple M2TS files... Playlist?
By Kartman in forum DVD RippingReplies: 1Last Post: 3rd Jan 2008, 16:14
