Trying to play a video with mp3 sound. Medianinfo says its mp3 2 channel. I thought you can play mp3 on ps3 or is that only under the audio tab? I can successfuly play audio and video with windows media player. Thanks in advance or any help.
Thread: Cant play mp3 on PS3
What is the video codec?
Mpeg 4 visual XVID Video plays great on ps3... Just not audio.
Load the video in a utility like GSpot or MediaInfo and post the information here (use a screenshot of the window if using GSpot, or Tree View if using MediaInfo. You can blank out the file and path/folder names, if you want.)
The PS3 can be a little picky about Xvid-encoded AVIs, but generally, you shouldn't have a problem playing an AVI with a DivX/Xvid video stream and an MP3 audio stream.If cameras add ten pounds, why would people want to eat them?
Here is the txt version of medianinfo tree. If there is something the PS3 doesnt like,could you please let me know what it is and why if possible? Thanks!
example.txt
Hmm... I'm not sure I can see anything about the audio stream, offhand, that the PS3 might not like. Someone else might see something I'm missing (it looks like an average MP3 stream, to me...
). As far as I can tell, a normal DivX/Xvid DVD player shouldn't have a problem with it.
One thing you can try is to demux the audio stream (no conversions), and see if the PS3 has any problems playing the resulting MP3. If it doesn't, maybe there's something else about the video (I still don't know why the PS3 is somewhat picky about Xvid AVIs as opposed to DivX... they should generally be about the same).If cameras add ten pounds, why would people want to eat them?
Yeah, the PS3 does support MP3 audio... I agree with Ai about demux... maybe even try a straight re-mux with DivX Mux GUI, which will re-package it all into a .divx container. You can get it free here:
http://labs.divx.com/DivXMuxGUI
The only thing I can think of is that maybe it thinks that track is a second/alternate audio track or not associated properly with the video? Hopefully, DivX Mux GUI can straighten it out.
Thanks again for the help guys...
I demuxed the Mp3 stream and the PS3 still wouldn't play it. Not sure what the issue would be with it though... Reencoded it to AAC and muxed it together and video and audio were fine.
Can I use my PS2 controller on my PS3 to play PS3 games?
By jbitakis in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 14:24 -
What files can PS3 play
By neworldman in forum Newbie / General discussionsReplies: 5Last Post: 9th Dec 2011, 11:13 -
What HD format will PS3 play?
By Floob in forum Video StreamingReplies: 6Last Post: 21st Feb 2011, 15:54 -
8x DL wont play in PS3
By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 14:16 -
How to transfer MP3 files to PS3?
By rcguy1 in forum Newbie / General discussionsReplies: 0Last Post: 24th Nov 2008, 08:38
