VideoHelp.com Forum
    Hello again gentlemen
    I'm on my way "almost" thanks to all of you.
    I want to capture the most amount of raw data (I plan to discard the tapes after successful capture). I'm going to guess AVI type 1 or 2 ?. When I use studio 12 with the Dazzle DVC100 hardware, I click the capture format settings AVI BEST it says Full DV Quality. Is this DV-AVI, AVI type 1 or AVI type 2?
    Stewart
  2. Mod Neophyte Super Moderator redwudz's Avatar
    With DV, Type 1 and Type 2 are just two different ways to store the audio with the video. Type 2 is more commonly used with VFW based editors like VirtualDub and encoders like TMPGEnc. You can convert between the two storage methods easily enough. It depends on which format your editor/encoder needs.
    More info: http://www.videohelp.com/glossary?D#DV
    'Full DV Quality' would probably just be (NTSC) 720 X 480 @29.97 fps and 48000 Hz PCM audio. About 13GB/hr. It could be Type 1 or Type 2. I don't know what Dazzle uses, but I would guess Type 2.
  1. Dazzle DVC100 BFF vs. TFF
    By Zabar12 in forum Capturing
    Last Post: 12th Jan 2012, 06:29
  2. Dazzle DVC100 Interlacing Problems
    By Imatk in forum Capturing
    Last Post: 25th Jul 2011, 18:25
  3. Replies: 14
    Last Post: 23rd Dec 2010, 04:56
  4. No Sound With Dazzle DVC100 using Virtual Dub
    By kpoman in forum Capturing
    Last Post: 3rd Nov 2009, 08:35
  5. Replies: 3
    Last Post: 29th Apr 2009, 22:48
