VideoHelp.com Forum
    Please HELP somebody , my problem is:
    I created subtitles with SubtitleWorkshop saved titles , with size 28 , for my plan its best size, when i preview it in SubtitleWorkshop they look big , the way i want.
    Next step with Virtual Dub open video, add filter subtitler , mytitle.ssa and i see them normal size again , why?
    What I have to do to save them with my chosen size???
    I found this at VirtualDub blog page. ::
    """The two most common questions I get about the subtitler filter I wrote are:
    * Why are my font sizes and border widths screwed up?
    * Why does my foreign-language text appear garbled?
    * Why don't my pictures and animations show up?
    Fortunately, both of these are easy to fix.
    This generally happens due to a missing or mis-set "PlayResY:" statement at the top of the file:
    Title: VirtualDub 'subtitler' filter demonstration
    Original Script: Avery Lee
    ScriptType: v4.00
    Collisions: Normal
    PlayResY: 240
    PlayDepth: 0
    Timer: 100.0000
    This field indicates the vertical height of the subtitling screen. Sub Station Alpha was meant to be used with a genlock, so it displayed your subtitles at desktop resolution and the entire screen was overlaid on top of the incoming video. Unfortunately, all of the sizes in an SSA script are in pixels, so the size of the screen is relevant; SSA stores the height of the screen in the PlayResY field.
    The subtitler filter assumes that you want to subtitle your video as though it were a full screen, so it scales all measurements in the script to match the screen resolution in the script. For most values of PlayResY it assumes a 4:3 aspect ratio, except for 1024, where it assumes 5:4 to fit the common 1280x1024 resolution. The catch is that if the PlayResY field is altered, all values in the script will be scaled. This is probably not what you want. If you are using Sub Station Alpha, remember that it was meant to be WYSIWYG, so the width of your screen will be shrunk to the width of your video!
    If the PlayResY: field is missing entirely, the subtitler simply uses the border and size fields verbatim as pixels"""
    But where is that file with those line to be altered? If i open subtitler.vdf with notepad, i see only mess. Where else it could be? Starnge autor says its easy to fix but explains not all.
    SOMEBODY IF YOU KNOW HOW PLEASE HELP
    Vitalij Spesivcev
    I guess you should ad the PlayResY: in the ssa subtitle file. You can also try alter the size in substation alpha(the BEST ssa editor ) and then save as a new ssa.
    I am still looking for solution, there was several posts about SSA , but pretty old ones , ond none of the links are working.
    Maybe You know the right one.
    I will try Your suggestion about add PlayResY: 240 in the ssa , we will see.
    When I am looking at the musubtitle.ssa through notepad the size set to 28, as i want it, though.
    Vitalij Spesivcev
    Solved:
    Thanks for help, actually everything is working, I installed VobSub 2.23 and TextSub2.23 filters for VirtualDub, they have options for style ( fonts , colors, size etc.), but strange thing ---now subtiltler by AveryLee its also doing the job, or its after installing new filters or not, can not say now.
    Vitalij Spesivcev
  1. Replies: 5
    Last Post: 11th Oct 2010, 11:01
  2. small video size, but showing incorrect size (too big)
    By mandy in forum Newbie / General discussions
    Last Post: 17th Mar 2009, 04:14
  3. Window size of video capture too small
    By rapattack in forum Capturing
    Last Post: 16th May 2008, 08:38
  4. Turn many small video DVDs to one standard size DVD
    By bryankendall in forum Newbie / General discussions
    Last Post: 30th Mar 2008, 17:57
  5. Video size too small in Adobe Premiere
    By sadievladimir in forum Newbie / General discussions
    Last Post: 23rd Mar 2008, 10:15
