VideoHelp.com Forum
Results 1 to 9 of 9
    hi,trying to author a dvd for karaoke.i had a go at this a few years ago and failed.i have all my clips ready to be authored. last time i did this,i could not get it to display main menu after playing each track. what i want to do is have my 10 or 12 clips displaying in the main menu or track window with a background video playing.once a track is played,i want the dvd to display back to the main menu. can this be achieved please as last time i did it,it kept playing the clips one after each other regardless of the settings. thanks
    u know me,i like free tv
    anyone have a solution or another dvd author program? i have a main menu with a track menu,within the track menu are 12 karaoke clips.i need to do it in a way so after each clip,i it displays the track menu or main menu. thanks
  3. Try guifordvdauthor, add some clips and analyze the dvdauthor.xml file if you want do do it yourself.
    hi,i managed to just use several tracks in the main menu,trouble is now,taking forever to encode it.
  5. taking forever to encode it.
    Then there is something wrong. GfD doesn't encode anything (except the menus). Check the log file...
    hi borax,i didnt us gfd. i just used dvd author and used a main menu with 12 tracks/12 clips. this is the only way to get it to work. for some reason when beginning output,i get to 3% then the estimated time goes up to over 3 hours,increasing. i have to abort.
  7. ...the estimated time goes up...
    AFAIK dvdauthor doesn't show anything like an 'estimated time'...
    About which dvdauthor program do we talk here?
    If it is this (command line) program: http://www.videohelp.com/tools/dvdauthor then again: Check the log file...
    If you talk about another program, which one?
    sorry,i should of said. i am using tmpgenc dvd author 1.6
  9. So please change your topic! Maybe someone with experience with tmpgenc dvd author may help you.
  1. Replies: 1
    Last Post: 8th Jul 2011, 22:01
  2. I need help with Karaoke DVD to Karaoke VCD(MPG)
    By adrianneow in forum Newbie / General discussions
    Last Post: 8th Jun 2011, 09:02
  3. Tmpgenc dvd author 3 will not author my m2v files????
    By biged670 in forum Authoring (DVD)
    Last Post: 28th Sep 2009, 11:10
  4. Replies: 1
    Last Post: 20th Aug 2008, 02:41
  5. Replies: 5
    Last Post: 18th Nov 2007, 15:07
