VideoHelp.com Forum
    Hello people,
    I have demuxed two m2ts streams(blu ray) with tsMuxer, the video stream and an dts stream. The input stream is also a m2ts stream(which has two other audio streams). I also have srt subtitles for this movie. I remuxed these three streams together, but the result when I play it with powerdvd 9 is the video without audio and without the subtitles. I am probably doing something wrong, but I don't know what. I thought tsMuxer was the program to use. Can one of you tell me how I can get the right result.
    Thanks a lot.
    Try play with mpchc and see if you can choose the subs.
    Or try make a new blu-ray/avchd using multiavchd with the subs and see if make any difference.
    Thanks for the advice but all my other players (vlc, classic home mediaplayer, zoomplayer) show an black border at the top of video during the whole movie. Powerdvd does not has this problem.
    When I open the output m2ts file in tsMuxer it shows all three streams.
    Your advice tells me i'm not doing something wrong, but i should use another player. I was hoping someone told me how to make an m2ts output file which plays fine in powerdvd. Maybe with another program?
    As told in the above, i also have another problem, the black border (it is not the usual black border at the top and bottom of a lot of movies) which takes away a part of the video. But maybe i should post that somewhere else.
    i have deinstalled cccp en installed it again, and mpchc now plays my file with the audio track without the black border, but i can't seem to get the subtitles to work. directvobsub shows up in the tray, but i cannot get it to work.
    does anyone know how to do this?
    to be more precise, when i right click on video in mpchc i see that subtitles are disabled but when i rightclick on directvobsub tray icon it shows the subtitle and i can select it, but it does not show up. does anyone know how to ressolve this problem?
    Up and running, i had to check/activate the subtitles in ffdshow, now it works. Let's see if i can get it to work on my laptop.
  1. Audio/video out of sync after demux-remux
    By CarryNL in forum Subtitle
    Last Post: 14th Sep 2011, 14:31
  2. 80% MKV remux on H.264 - M2ts remux Aero Theme
    By BJ12 in forum Video Conversion
    Last Post: 12th Aug 2011, 12:59
  3. remux to (TS vs M2TS)
    By Data-Base in forum Video Conversion
    Last Post: 19th Apr 2009, 15:50
  4. can not remux after demux
    By volam in forum Editing
    Last Post: 19th Mar 2009, 15:36
  5. Remux m2ts with DTS to m2ts
    By eummagic in forum Blu-ray Ripping
    Last Post: 13th Mar 2009, 20:03
