well hello all i decided to rip my Buffy dvd's season 1 i tryed so many programs i came across useesoft dvd ripper this worked great i put the dvd in went to start i ticked the episodes. i chose the output format to mkv i fixed the mkv settings to h264 while its ripping the dvd plus converting the mkv file is 500mb is their anyway of shrinking this without the loss of quality i
No.Originally Posted by rko2164
can you tell me why
1) The act of "Ripping" a DVD gives you an exact copy of the DVD.
2) What you are doing is converting or "compressing" the original down in size which WILL result in quality loss. Whoever told you otherwise is lying.
...and that would most likely be around 4.5 GB for a single-layer DVD, or over 9 GB for a dual-layer DVD, as I recall. rko2164, you're having the ripper convert the DVD to compressed video as (or after) it rips, which is already a reduction in quality. If you want smaller videos, is it possible to set the ripper to create smaller videos? (Of course, that'll still make the quality worse than the original DVD. Whether or not that's acceptable, is up to you.)Originally Posted by hech54If cameras add ten pounds, why would people want to eat them?
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping a DVD
By andreltr in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 09:29 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
Ripping DVD'S
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 04:14 -
HD DVD Ripping
By joco200 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2007, 15:14
