There's very little known about the use of the FFmpeg subtitle commands.
I once was able to mux-in a vobsub subtitle in a vob with the "-scodec copy" command and FFdshow could display it. But the color settings for a DVD subtitle come from the IFO's so it didn't really looked useful.
AFAIK, subtitles in vobs only work properly in a full DVD structure as created with a DVD authoring program.
Why is the original post removed
This was a reply on a question by someone from Hong Kong
IMO there was nothing wrong with the question.
Original question
Hi,
I'm trying to use ffmpeg to add subtitle into the vob file, but with -newsubtitle option,
it does not work; So would someone show me an example to use this function?
Thanks...
But the user wont be able to answer.....spammer....banned and deleted.
You may have a hard time finding people who would use your methods to add subs to a VOB, since there are simpler ways to do it -- but yes, those simpler ways involve DVD authoring programs. Nevertheless, you can keep the DVD structure fairly simple. DVDAuthorGUI is free, and looks somewhat simple. (I'm not completely sure, since I use the similarly-named but more complex GUI for DVDAuthor.) There does not need to be a re-encode of the video and audio files, just a step to set the color parameters of the subs, followed by muxing all the elements together.
I'm not sure I understand your objections to using DVD authoring software for muxing purposes.
Hi,
regarding ffmpeg documentation it should be possible but...
see this post :
http://www.box-pirates.to/thread.php...399#post447399
bye
FFMPeg trying to add image before flv file to get 3gp
By wingchun22 in forum Video ConversionReplies: 4Last Post: 25th Jul 2008, 22:09 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
How to add watermark to a video with mencoder or how to scale with FFmpeg?
By ApplePro in forum Video ConversionReplies: 16Last Post: 21st Nov 2007, 09:12 -
ffmpeg engine - how to add matting to 3:4 videos for 16:9 screens
By psychicmind in forum ffmpegX general discussionReplies: 1Last Post: 18th Nov 2007, 13:13 -
Can't add assetts in V2.5.2720, ffmpeg hangs.
By gealto2 in forum SVCD2DVD & VOB2MPGReplies: 15Last Post: 28th Jun 2007, 18:45
