I have an avi file (I ripped the DVD with Fair Use Wizard) on a DVD disk, 2.8GB, 3 hours 3 minutes. The disk plays fine on my computer with Media Player Classic (and shows the correct running time), but on 2 different standalone DVD players that I tried, the avi movie is truncated at 2 hours 16 minutes. One of the players shows the incorrect running time as 2 hours 16 minutes.
My question is: Is there a avi file size limit for DVD players? It seems that if I encoded the move to be 1.4GB (instead of 2.8 GB), I could have avoided this problem.
I see.
Any of the following Divx encoding options might cause DVD players to have problems.
4) Files larger than 2 GB in size.
Some very old players had a 1 GB size limit.
yeah, i also happen to such problems. it seems that there is limitation on some dvd players.
Happy to bet that if you cut the file at the 2:16 mark, you get a 2 GB chunk. I have on player that will happily start to play files larger than 2GB, but simply stops at that point.
standalone dvd players: is there a file restriction view limit?
By mike69 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 4th Jan 2009, 08:27 -
Vegas AVI 2gig rendered file size limit
By Gargalash in forum EditingReplies: 2Last Post: 17th Nov 2008, 09:12 -
Is There a Practical File Size Limit For Streaming FLV?
By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 09:13 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
VDub/MOD cant limit my file size?!?!
By GangstaRap in forum Video ConversionReplies: 6Last Post: 29th May 2007, 04:36
