Does a DVD movie have 7.1 channel or only blu-ray DVD has 7.1 audio? If so, how to burn a DVD with a 7.1 channel?
Only Bluray disc support 7.1 channels audio.DVD is up to 6.1Originally Posted by coody
Cheers!
The DVD-Video specs do allow 8-channel PCM (6,144kbps),
however I still haven't found any hardware player that supports it.
Deleted
DVD supports 6.1 through DTS-ES and 7.1 through Dolby Digital EX - if your amplifier supports it.
After copy of the blu-ray DVD, can the copied DVD still keep 7.1 channel audio? If so, what tool can copy the blu-ray DVD with 7.1 channel audio or the audio will change to 5.1 channel after copy?Originally Posted by 7saigon5
If you are converting Bluray to DVD you cannot keep the original audio if it is HD. DVD spec does not support it, and your player won't play it. You can strip it down to DVD spec audio though.
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 13:14 -
Burn more than 1 movie on same DVD
By smithwigglesworth0 in forum Authoring (DVD)Replies: 20Last Post: 31st Aug 2011, 22:34 -
6 channel audio gets mixed up during a point in movie
By Event3horizon in forum Authoring (Blu-ray)Replies: 6Last Post: 17th Jul 2010, 19:49 -
video in my Windows Movie Maker project was missing an audio channel
By DaneClark in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2009, 19:52 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46
