Is there a way to change a DVD from color to B/W using a program like MPEGStreamclip or MyDVDEdit? I have a DVD that was transferred from VHS and the image is either B/W with pink, blue, green VHS specks or it is very poor color that appears to be washed out, but the specks dominate the image. I know that it is impossible to truly fix the image but if I can change it to B/W it would be more watchable. I also know that I can just fix the contrast on my TV but I want to send the DVD to some friends and I prefer not to have each of them mess with their TV sets if I can just fix the DVD on my own. Here is what the image looks like if you are curious.
Thread: Switch image from color to B/W
MPSC means a re-encodingOriginally Posted by danielmak
myDVDEdit just change display informations (so, will not correct your video)MyDVDEdit
You have 2 solutions;
- use your remote control to decrease TV color
- re-encode to suppress the color channels (most of freeware/shareware encoding softwares will does the job: the FFmpeg open-source library has this function, and almost evry soft use FFmpeg
PS: no hope with iDVD
byeSome drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08)
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 2nd Feb 2009, 21:16 -
NERO Image speed switch?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2008, 10:25 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23 -
CSS/HTML background image/color code help
By lordsmurf in forum ComputerReplies: 2Last Post: 26th Sep 2007, 19:29
Statistics
Newest guides
Latest tool updates
New media comments
