Hi, I'm new to the site.I plan to by a Blu-Ray Player and need to play all R#'s and all A#'s.
I was on a site last month and found the DMP-BD60 from Panasonic there and the listed it as region-free from the manufacturer. I went to vanns website and asked of their model was the same, and the salesperson said yes.
I have the money to purchase it and just in case, asked the question again, & the e-mail reply was that it was not made region-free for either dvd or blu-ray discs & that a code needed to be used and it definitely can be done.
Looking on your hack list, there are no codes,
I have about $150 and can but this model at amazon today for the (hidden price of under $120) while at vanns (under $130) but I can't afford to buy a player for more tha that (I am disabled and only have an income from my SSI(under $700/month) but have saved up for one. If someone knows the codes for the US model or can suggest one (from US or another country) that is under $150 (I've looked at some UK sites and the factory made ones are at minimum (with shipping of over 200 pounds stirling which convert to over two and a half times as much as I can spend.
Thanks for reading, and special thanks if you can help me as well,
markwho1
Results 1 to 1 of 1
Panasonic DMP-BD85 - no valid hack posted!
By k-real in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Aug 2010, 01:02 -
Panasonic DMP-BD60 Hack Help
By rmunrohfc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 16th Apr 2010, 15:02 -
AVCHD Disk on Panasonic DMP-BD60
By rjesse in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Apr 2010, 09:21 -
blu-ray DMP-BD60 any problems or glitches?
By Knightmessenger in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2010, 22:46 -
? regarding the hack for panasonic dmp-bd35
By pfloyd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Jan 2009, 08:27
