VideoHelp.com Forum
    I'm trying to create an AVCHD disk out of some episodes of a TV show, but for a couple episodes it won't let me. Here is what it looks like:
    [23:25:10] Processing (C:\Users\*******...
    [23:25:11] Detected frame reference count: 2 (max:7).
    [23:25:11] Detected video: ID#1:V_MPEG4/ISO/AVC 1280x720, fps=23.976, ref=2
    [23:25:11] Detected audio: ID#2:A_AC3 (48000Hz 6ch) Language: und
    [23:25:11] Added audio: A_AC3, "C:\Users\*****.mkv", track=2, lang=und, timeshift=0ms
    [23:25:11] M2TS stream split set at 3999MiB...
    [23:25:11] Creating clip and playlist info (tsMuxeR)...
    [23:25:16] Cannot detect file size: (C:\Users\******\AppData\Local\Temp\_multiTMP\2009 1205-232511-2615\BDMV\STREAM\00000.m2ts)
    tsMuxeR (Version 1.10.6) output:
    Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1280:720p Frame rate: 23.976
    Change H264 level from 4.1 to 4.1
    H.264 stream does not contain fps field. Muxing fps=23.976
    H264 bitstream changed: insert nal unit delimiters
    H264 bitstream changed: insert pict timing and buffering period SEI units
    Decoding AC3 stream (track 2): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 2
    tsMuxeR meta:
    MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:20:00.000 --split-size=3999MiB --vbv-len=500
    V_MPEG4/ISO/AVC, "C:\Users\******.mkv", insertSEI, contSPS, track=1, lang=eng, level=4.1, fps=23.976
    A_AC3, "C:\Users\*********.mkv", track=2, lang=und, timeshift=0ms
    [23:25:16] Important files missing (clpi/mpls/m2ts)...
    [23:25:16] Possible tsMuxeR failure to process your input file (C:\Users\*******.mkv).
    [23:25:16] M2TS (media) file count: 1
    [23:25:16] CLPI (clipinfo) file count: 0
    [23:25:16] MPLS (playlist) file count: 0
    [23:25:16] Skipping to next...
    Have you tried run tsmuxer or mkvtoolnix to manually demux those troubling mkvs? To see how if it works. Then maybe you can import the separated streams in multiavchd.
    Just tried that with tsmuxer and right when I loaded the file it said "Some tracks not recognized. This tracks was ignored." I tried to demux anyway and it gave me just 1 file: a .264 file that wouldn't play. Is there something wrong with the file? Because 2 of the 10 episodes have this problem, but the other 8 work fine.
    Any ideas?
  5. I'm a Poll Super Moderator johns0's Avatar
    Load the mkv into eac3to gui and save as ac3 and then load the new ac3 with the mkv into tsmuxer and save.
    Ben Johnson-I didnt take any stereos!
    Heh, eac3to is completely over my head. How exactly do I use this program?
  7. I'm a Poll Super Moderator johns0's Avatar
    Search the forum,theres lots of threads and guides and i have given help so many times on how to use eac3to.
  1. Problem remuxing with multiAVCHD
    By jadasneez in forum Authoring (Blu-ray)
    Last Post: 13th Jan 2012, 16:08
  2. multiAVCHD menu problem
    By Clydesdale in forum Authoring (Blu-ray)
    Last Post: 27th Nov 2011, 23:15
  3. multiAVCHD problem
    By obadvw in forum Authoring (Blu-ray)
    Last Post: 17th Nov 2011, 16:02
  4. multiAVCHD syncing problem
    By dan_man555 in forum Video Conversion
    Last Post: 30th Jun 2011, 21:41
  5. Is multiavchd a problem?
    By volam1 in forum Authoring (Blu-ray)
    Last Post: 4th Oct 2009, 15:19
