VideoHelp.com Forum
    Hi, i have a little problem. The thing is, i have a tv show in DVD format (10 episodes), but without a menu.
    It's very difficult this way to navigate those episodes, so i would like to know what's the easiest way to add some basic (only episode list) root menu to this DVD, but without recoding the video?
    Thank you in advance.
    you'll need an authoring program like dvdlab pro. you can import the vobs and it will demux them into the video and audio parts and allow them to be used without re-encoding to make a new dvd with menu. you'll need to make the menu though.....
    maybe someone else knows an easier way.
  3. I'm a Poll Super Moderator johns0's Avatar
    If you want an easy solution try tmpg dvd author,for the cheapest way use DVDAuthorgui.
    Ben Johnson-I didnt take any stereos!
    Womble's new EasyDVD can do this with minimum of fuss. So can VideoRedo TVSuite.
    For free, try DVDStyler or DVDAuthorGUI.
    Thank you all for your suggestions, especially ZQX.
    EasyDVD did the trick - the project was finished and ready in under 15 minutes. Very nice and simple tool.
    Thanks once again.
  1. Recoding mov to Xvid .avi
    By coyote2 in forum Video Conversion
    Last Post: 28th Dec 2011, 17:01
  2. Possible to change ref frame value w/out recoding?
    By dave in or in forum Video Conversion
    Last Post: 2nd Aug 2011, 20:11
  3. Question about BD recoding (ripbot)
    By m3tallica in forum Authoring (Blu-ray)
    Last Post: 9th Apr 2010, 22:11
  4. inserting a menu with chapetrs
    By scamperoo in forum Authoring (DVD)
    Last Post: 22nd Feb 2008, 19:38
  5. Recoding from AVI player
    By GJF in forum Newbie / General discussions
    Last Post: 16th Jun 2007, 09:00
