For those of you who want to control Vista Media Center using your iPhone or iPod Touch I recommend you to check out an application called inControl. For example, it shows the program guide (same information as in Media Center) in the iPhone/iTouch application instead of forcing you to browse the guide using the normal arrow buttons. It also includes support for controlling TVs, projectors, or any other device you might have connected to your computer (using RS-232).
The application also contains Wake-on-LAN support, mouse pad, view for containing the normal Media Center buttons (enter, backspace, arrows, play, pause, rewing, volume,...), and sleep timer.
More information can be found here:
http://www.incontrol.byethost7.com
The App Store application can be found here:
http://itunes.apple.com/app/incontrol/id342279450?mt=8
Screenshots of program guide views:
Note: The text in these screenshots is in Swedish since the Media Center used to make these screenshots was in Swedish. The application will show the same information as displayed in your Media Center.
Results 1 to 1 of 1
Is the Ipod touch 2G the same size as the Iphone?
By ryangarfield in forum Portable VideoReplies: 0Last Post: 28th Oct 2008, 00:20 -
ipod touch/iphone
By Kurgan71 in forum Video ConversionReplies: 0Last Post: 27th Aug 2008, 10:50 -
encode-handheld.pl v2.5 (encodes for PSP, Zune, iPod, iPhone, touch)
By HolyRoses in forum ffmpegX general discussionReplies: 0Last Post: 23rd Jul 2008, 01:36 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33 -
Will a Microsoft Remote Control for Win Media Center work
By canadateck in forum Software PlayingReplies: 6Last Post: 17th Dec 2005, 23:36
