VideoHelp.com Forum
    Ok guys,
    i have Eac3to and ArcSoft Total Media Theatre.
    I've got a file with these properties
    1920x1080 at 23.976 fps, MPEG-4 AVC , ~26,5 Mbps avg
    English: 48 kHz/24-bit, DTS-HD MA 5.1, ~4094.00 kbps avg
    It's a M2TS file,
    i plan on using Tmuxer to get the DTS-HD MA 5.1 file out and then i plan on using Eac3to convert it to 5.1 DTS (My surround only accepts DTS/DD)
    Is this possible?
    Im a noob but i dont understand the fact that this DTS-HD MA is 24bit and ive never seen a 24bit DTS file.
    Will it convert it into 16bit etc?
    I know quality will be lost because its Lossless > Lossy because of the bitrate but does the 24bit matter? etc but i dont mind as i WANT the 26.5 Mbps Video =D
    If you just want do dump the DTS core, there is an option in tsmuxer (checkmark "downconvert DTS-HD to DTS" when demuxing)
    Alternatively in eac3to
    eac3to input.dtshd output.dts -core
    I know ill lose like twice the bitrate in quality but will anything else be affected?
    im confused regarding the 24bit
    No the core would still be 24bit, to convert to 16bit
    eac3to input.dtshd output.dts -core -down16
  5. Member yoda313's Avatar
    I guess I'm confused why you are bothering to convert the audio at all. As long as your receiver can play dts you should be able to play any type of dts.
    I have a playstation 3 and an older non-hdmi receiver that does dolby digital 5.1 and dts 5.1 but not the hd audio variants. I have no problem getting dts out of a dts-master hd audio bluray movie.
    What device are you playing this on? I would test and make sure it won't accept the orginal audio first before spending time converting.
  1. How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
    By fits79 in forum Newbie / General discussions
    Last Post: 29th Jun 2011, 22:30
  2. How i can convert dts-es to dts-core from one mkv file?
    By fits79 in forum Video Conversion
    Last Post: 11th Jun 2011, 21:24
  3. Convert DTS-MA to DTS with XMedia Recode?
    By smackyourfupa in forum Blu-ray Ripping
    Last Post: 14th Apr 2011, 08:23
  4. Replies: 0
    Last Post: 12th Mar 2010, 12:10
  5. DTS encoded disk, output to DTS receiver using an HTPC
    By ChipMcC1 in forum Media Center PC / MediaCenters
    Last Post: 18th Nov 2007, 07:06
