years ago i authored some DVDs with family captures. Now, i want to author other DVDs, replacing a couple of clips, conserving the original menues and structures. Do any know how to do that ?
thank you very much !
best regards,
nachomur
Vobblanker, click on it for guides.
thank you Baldrick ! i will try it !
best regards,
nachomur
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 9Last Post: 24th Jun 2011, 04:56 -
Replace audio on a DVD
By danielmak in forum MacReplies: 7Last Post: 31st Oct 2010, 22:40 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
What's on the horizon? Is Blueray likely to replace dvd?
By Haopengyou in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2010, 13:27 -
Can you replace a VTS on already authored DVD?
By kpic in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2007, 07:36
Statistics
Newest guides
Latest tool updates
New media comments
