VideoHelp.com Forum
  1. Hi,
    When I try to burn an iso image (with Nero or ImgBurn) it fails while finalizing the disc. "PMA error" if I remember well.
    The iso is an home made with imgburn with DVD video structure.
    If I burn the folder instead of the iso it passes without problems.
    So I sacrified some disc to try, each time I burn an iso (home made or downloaded linux iso) it fails.
    If I burn the content extracted to a directory is succeed.
    What can be the problem ???????
  2. Member MOVIEGEEK's Avatar
    Are these SL or DL?
  3. Member MOVIEGEEK's Avatar
    Post an ImgBurn log, maybe someone can figure it out.
    How big is the ISO file?
  4. I don't keep the log file And I don't want to kill another empty dvd for now by testing an iso.
    The ISO is about 3.92 GB
    Imgburn automatically saves the logs, under "Help" menu. Each burn log is appended to the previous ones, so unless you explicitly deleted or otherwise turned logging off, it's saved.
  1. Burning DVD with VIDEO_TS Folder
    By bguguen in forum Mac
    Last Post: 28th Jul 2009, 00:10
  2. Help with burning a video ts folder
    By molinman in forum Newbie / General discussions
    Last Post: 15th Dec 2008, 02:39
  3. Burning folder with DVD Author 3
    By Matt D in forum Authoring (DVD)
    Last Post: 11th Aug 2007, 15:06
  4. Replies: 14
    Last Post: 26th Jun 2007, 15:19
  5. help burning video ts folder?
    By pbure0110 in forum Video Conversion
    Last Post: 21st Jun 2007, 21:39
