Hello all.
I currently use my Xbox360 to stream HD media from my PC to my TV set. I've been happily converting my MKV collection which most of the time has either an AC3 or DTS track to MP4s with 2 Channel AAC audio (This is an Xbox360 limitation). I've been using MEGui to do this and so far it has worked a treat. My usual work flow is as follows:
- Extract Audio/Video/Subs from MKV with MKV Extract.
- Convert AC3 Audio with MeGui (Downconverting 6 Channels to Stereo in the proccess).
- Muxing the Video/Audio/Subs back into an MP4 (With MeGui)
The problem arises with a few MKVs I have that I used 6 Channel ACC on. I can extract the Audio just fine with MKVExtract. The conversion proccess from 6 Channel to Stereo is a problem. MeGui throws an error, It can't use Directshow to decode the audio. Xvid4PSP just chokes and causes VS2008's Debugger to kick in and then exits. Besweet Won't convert it either.
I've installed FFDshow and also installed Coreaac but neither helped. Graphedit tells me it can't render the file. I honestly don't know where to go from here. I thought it was a simple matter of not having the appropriate codec installed to decode aac, But that doesn't seem to be the case (Unless i've missed something). The files plays fine in Foobar2000 - So I'm pretty much fresh out of ideas.
Can any one shed some light as to what might be going on here? Any input would be appreciated, Even if it's just a nudge in the right direction. As alwats, Thank you from reading.
ffmpeg error when encoding 6 channel aac
By BrianAtVH in forum AudioReplies: 5Last Post: 14th Feb 2012, 14:52 -
Batch Convert 6 channel AAC to AC3?
By massarosareloud in forum Video ConversionReplies: 11Last Post: 22nd Oct 2011, 14:41 -
6 channel/5.1 channel AAC
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2010, 15:15 -
How to convert a 6 channel aac to ac3?
By nasdravi in forum AudioReplies: 11Last Post: 15th Feb 2010, 22:01 -
Properly encoding multi-channel AC-3 to multi-channel AAC
By PuzZLeR in forum AudioReplies: 1Last Post: 15th Nov 2007, 13:07
Statistics
Newest guides
Latest tool updates
New media comments
