VideoHelp.com Forum
  1. Hi, I have some HD clips from my video camera which are all in avchd/mts format. They playback ok in media player classic but with no audio, they play with audio but choppy video in VLC player and with media player classic home cinema I get neither video or sound, does anyone know why ?
    I can load the clips into adobe premiere for editing and they work fine in there. Also would that be a good program for adding some good opening titles etc ?
    Thanks.
    What format is your audio? use mediainfo
    Try installing haali media splitter + ffdshow + ac3filter
    MPCHC should work, if you configure it properly for your audio & video in the options. Another option is KMplayer or SMPlayer or Splash
    What do you have in mind for titles? Premiere has a titler than can handle most types of simple titles. If you want something more advanced with motion graphics and something more fancy, you could use after effects
  3. Thanks for the advice. I have the software you mentioned already so I think it might be an option I have not selected somewhere. MPCHC plays with no picture but perfect sound.
    Here is a shot of my options screen in mpchc
    If you are using mpchc , you need to enable the source filter, proper audio and video in the transform filters. Look under options=>internal filters (it's the heading right below your screenshot in the tree view)
    For source filter enable mpeg ps/ts/pva, for transform filters enable h.264 since it's avchd. Double click it to configure the options (e.g. decoding thread number for multicore). Or if you have dxva compatible graphics card, enable the dxva option for smoother playback. If you're getting choppy playback, it's probably because your computer is too old
    Or you could go the other route and install the other programs (haali splitter, ffdshow, ac3filter) , which will enable directshow playback on other video players like MPC
  1. Merge HD MTS (AVCHD) files
    By foxnews in forum Video Conversion
    Last Post: 28th Jun 2011, 08:18
  2. AVCHD - join MTS files
    By cmichel04 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th May 2011, 11:55
  3. AVCHD/.mts editing and conversion help?
    By fox's box in forum Video Conversion
    Last Post: 20th Sep 2010, 04:00
  4. Choppy/jerky AVCHD/mts playback on my computer
    By rlubocki in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 25th Dec 2009, 13:14
  5. Replies: 8
    Last Post: 23rd Jul 2008, 23:02
