VideoHelp.com Forum
    I have installed ffmpegx and followed the instructions to convert a video. When I go to convert it, the conversion progress bar goes to complete in about 1 sec (it's a large video so not possibe) and there are no files in the output directory
    Any ideas would be appreciated
    Post the log file for examination on any errors. You may access this log by clicking the blue "i" in the ffmpegX Progress window after a conversion attempt.
    I'm having a similar problem. I am triing to convert a RM file to a Mov file. Here is my log:
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Wed Dec 2 11:16:11 PST 2009
    [NULL @ 0x54340c]Unsupported video codec
    Input #0, rm, from '/Users/charlie/Documents/websites/CLLS Original/litfilm/realmedia/linda.rm':
    Duration: 00:03:01.4, start: 0.000000, bitrate: 240 kb/s
    Stream #0.0: Data: 0x0000, 32 kb/s
    Stream #0.1: Data: 0x0000, 167 kb/s
    Stream #0.2: Data: 0x0000
    Stream #0.3: Audio: sipr, 8000 Hz, mono, 6 kb/s
    Stream #0.4: Audio: cook, 22050 Hz, mono, 32 kb/s
    Stream #0.5, 12.00 fps(r): Video: RV40 / 0x30345652, 320x240, 27 kb/s
    Stream #0.6, 12.00 fps(r): Video: RV40 / 0x30345652, 320x240, 167 kb/s
    Stream #0.7, 12.00 fps(r): Video: RV40 / 0x30345652, 320x240, 27 kb/s
    Codec type mismatch for mapping #0.0 -> #0.0
    When I try to play the movie I get a message that says: The file is not a movie file. Could not be opened.
  4. Explorer Case's Avatar
    Originally Posted by cjoshea
    RM to Mov.
    ffmpeg cannot decode RM, you'll need a mencoder preset.
    I've just had the same issue with a mencoder preset, myself. I'm converting from .avi to h.246 mencoder, and it only took a second to ding.
    It doesn't really matter to me what the output is, though, so long as it's .avi of some sort in its final stage, without any noticeable quality drop. I was trying XviD mencoder before this and the exported files became quite grainy. Despite playing with various settings under the Video and Options tabs, I haven't had much luck finding a way to export that I'm satisfied with.
    I'm using ffmpegX for the purpose of subtitling only, so I really don't want a change in video quality. End size doesn't matter to me either... I'm really newbie at this and I don't find it intuitive, so does anyone have any suggestions as to good target formats and settings? I'd appreciate it! Meanwhile, I'll keep tinkering to see if I can find something that works...
  6. Explorer Case's Avatar
    Originally Posted by aeslis
    I've just had the same issue with a mencoder preset, myself. I'm converting from .avi to h.246 mencoder, and it only took a second to ding. It doesn't really matter to me what the output is, though, so long as it's .avi of some sort in its final stage.
    H.264 mencoder won't output as AVI, but as MP4.
    I was trying XviD mencoder before this. I'm using ffmpegX for the purpose of subtitling only.
    For AVI output with burned-in subs, keep the preset at XviD mencoder.
    If output size is no real concern, then just optimize the quantizer values in the Options tab, for high quality output: Qmin=2, Qmax=2. That should do it.
    You are superb! I will try that. Thank you so very much indeed.
  1. AVStoDVD stops working after encoding video
    By tperkins13 in forum Authoring (DVD)
    Last Post: 19th Apr 2011, 07:10
  2. Replies: 14
    Last Post: 11th May 2008, 18:23
  3. RMVB Playback/Encoding Not Working
    By blazingtony in forum ffmpegX general discussion
    Last Post: 13th Mar 2008, 23:50
  4. Encoding to Flash not working?!?!
    By Yankeecom in forum ffmpegX bugs and suggestions
    Last Post: 27th Aug 2007, 19:38
  5. Installed Mac OSX updates, and PS3 (IPOD) encoding stops working
    By limeyx in forum ffmpegX general discussion
    Last Post: 12th Jun 2007, 18:58
