I got this kinda old audio track recorded from TV and it sounds muffled, as if it was coming from inside a glass bubble. How could I enhance it, making it sharper, brighter? I have included a small sample. Thanks in advance!
videohelp.mp3
Thread: How to improve muffled audio
"The file you are trying to access is temporarily unavailable."
You can also include files when you post in our forum, just add it under the upload image/file.
Ok, I have edited the post included the file. Thanks for the warning.
Try using the freeware audio editor Audacity and play with the high pass/low pass filters.
I did this in Audacity using the Classic EQ and Amplify effect, I boosted everything about 6dB:
http://audacity.sourceforge.net/download/nyquistplugins
videohelp.mp3
Very nice tip, the audio got much clearer, only I had to remove noise in Audition (this feature in Audacity doesn´t seem to produce goos results).Originally Posted by redwudz
Thanks redwudz!
Just a generalization, but all filters remove something. As long as it's just noise, great. But sometimes it's dynamic range. Less is usually better with filters. That said, I have seen some very good improvements with audio filtering. Cutting out the low frequencies and the higher frequencies helps some audio with rumbles and squeaks. With a editor like Audacity, you can experiment with different filters without damaging the original audio. Try a few different filters and see what you can do. If you don't like it start over.
Couple weeks late, but just saw this thread.
Sound Forge would fix most muffling, easy: http://www.digitalfaq.com/guides/vid...soundforge.htm
As redwudz says, you alter/augment the audio. Sometimes loss is noticed, sometimes not. The end-goal is to make it better, not make it perfect.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Remove muffled audio?
By danilson in forum RestorationReplies: 4Last Post: 4th Jun 2011, 17:08 -
muffled audio from a very old tape
By snafubaby in forum AudioReplies: 3Last Post: 22nd Nov 2009, 23:52 -
Is there any way to improve audio from a movie ??
By hilario in forum AudioReplies: 8Last Post: 20th Sep 2008, 12:14 -
question about demagnetizing audio head on VCR to improve audio
By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2008, 16:47 -
Audio Sounds Muffled
By NBninja8 in forum CapturingReplies: 1Last Post: 25th Jan 2008, 23:53
