After I added the Sample Grabber filter between the demux and Render, the video part will "freeze", but the audio works well. Do you know why?
Is there any sample?
Thread: DirectShow Sample Grabber filter
What are you doing? Graphedit? or what?
After insert SampleGrabber filter between video decoder and video render, it only can display first frame. How to keep deliver incomming data from decoder filter to renderer filter?
I would like to use the grabber to compare the video and audio after decoder and the input, in order to check the quality by programme instead of naked eyes. I have finished the compare part, the rest of the problem is cannot the image buffer and at the same time keep playing.
Directshow filter for the Animation codec
By roflwaffle in forum Video ConversionReplies: 8Last Post: 12th Oct 2010, 15:09 -
DirectShow Filter Problems
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 2nd Oct 2008, 22:12 -
CCCP - DirectShow filter pack
By joepic in forum Newbie / General discussionsReplies: 10Last Post: 31st May 2008, 08:11 -
Which one directshow filter to resize the image ?
By jazzzy in forum Software PlayingReplies: 1Last Post: 20th Feb 2008, 09:55 -
Directshow filter being used...
By fabvideohelp in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2007, 12:27
Statistics
Newest guides
Latest tool updates
New media comments
