I have a very large 1080 MKV which is around 10GB that I'd like to put onto two DVDs for watching on a standalone player. Does anyone know of any good conversion software that can create the two images with minimal loss in video quality? I can do this on a virtual machine in Windows XP or Windows 7, but I'd prefer to stick to OS X if I can. Thanks!
Thread: Large MKV split on two DVDs
What type of standalone player ?
If fit is not a HD player capable player then you can forget about minimal image quality loss.
If you have a bluray player that can play AVCHD discs, or a PS3, I would recommend Multi-AVCHD to compress it to fit on a DL DVD, or use the stream results from this with TSMuxer to create two SL DVD AVCHD discs.
All of this is W7 software.
Thanks for the feedback! It's a bluray player, but I think it's an older one. Unfortunately, I can't get the exact model number so I can't tell if it can play AVCHD discs (and won't know until I go to play one in it).
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 09:37 -
Any advice on how to split a large AVI into smaller clips easily?
By Bluelude1 in forum CapturingReplies: 11Last Post: 19th Jun 2011, 11:55 -
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
large file split for multiple displays and convert ... what tool 2 use?
By rodpacker1 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:03 -
How to split a large movie with DVDFab Platinum
By Firewire60 in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2007, 01:51
Statistics
Newest guides
Latest tool updates
New media comments
