Hello All,
Using a JVC Pro series player, played a VHS tape through once, played nicely, on replay it is just black with white streaks. Tried playing it through another machine NO LUCK still black. Any help out there? I seen this same problem on a post from 2005. Was hoping someone figured something out by now. Thanks
Have you visually inspected the tape? It may be mechanical damage. Can you wind it back and forth? If you push the small button on the L side of the cassette, you can open the front tape door and take a look at the tape. Look for wrinkles, lots of oxide dust and frayed edges. Don't touch the tape with bare hands though.
And welcome to our forums. -
Hello,
I can wind it back and forth. No frayed edges or excess dust of any sort.
Could my machine of stretched the tape? The JVC sure has a fast forward and reverse. Thanks Again -
Just my experience, but stretched tapes usually show some obvious edge damage from the stretching. One slight possibility is that the deck erased the tape, though there should be quite a few safeguards against that.
Maybe other members have experienced a similar problem, or have some better suggestions. Just stand by...... -
Does the tape have a play-once "feature" on it? This is a hidden eraser strip on the tape. If this is the case, you're screwed. Screeners were often released this way in the 90s, I saw many of them as an entertainment editor/reporter. I used to cheat, dismantle the tape (or drill it out), and swap shells with a cheap $1 blank. Some were simply a piece of crap magnet taped into a standard cassette, just yank it out.
The other option is the VCR has an issue, and it's erasing the tape as it plays. This would be a mechanical failure of the erase heads.Want my help? Ask here! (not via PM!)
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 12:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum CapturingReplies: 0Last Post: 19th Feb 2012, 15:52 -
Recovered Mp4 video not playing, any hope of repair ?
By Pintofshite in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 10:50 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 09:32 -
Help! VHS tape suddenlt decided to stop playing. Some sort of configuration problem..
By stevie P in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2010, 13:24
