VideoHelp.com Forum
    I have vids like that ... I want to stream it on youtube with the same DAR and without quality loss
    Codec ID : XVID
    Bit rate : 920 Kbps
    Width : 716 pixels
    Height : 382 pixels
    Display aspect ratio : 1.874
    Frame rate : 25.000 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    this is a chuck :
    http://www.mediafire.com/?bzbmmtgyl92
    When i upload it on Youtube I get good quality but with wrong DAR
    here is an example:
    http://www.youtube.com/watch?v=vG-OZJ9arkk
    THANKS
    Try resize to a standard 16:9(dar 1.777) resolution like 640x360 and then upload.
  3. Member MOVIEGEEK's Avatar
    856x480 is also 16:9 and looks good on YouTube.
    Here's clip I did using the default wmv settings in Sony Vegas, it seemed to keep it's ar http://www.youtube.com/watch?v=7MXXxZoNiXw
    Thanks to all , but I want my vids to be shown with the right DAR.
    * resizing to 640x360 or other means stretching the image because DAR is not 4:3 or 16:9 , it is 1.87:1
    * Re-cropping means data loss because these vids are cropped before.
    I found two primary solutions :
    1 - Bad solution ; adding this line in TAGS yttretch=16:9 (the original DAR is not 16:9 but it is near of that)
    ==> this reduces the quality & when I save it , I get the buggy DAR "4:3" 720x576
    as here http://www.youtube.com/watch?v=vG-OZJ9arkk
    2 - Youtube encoder causes this matter with (Xvid) codec When I tried (AVC/H264) "YOUTUBE recommendation" the problem is solved but with lower quality & higher size.
    as here http://www.youtube.com/watch?v=p7uMOSQXw_w
    youtube would prefer h264 mp4. start over with the original source and use a higher bitrate if you see quality loss. 4-5 mbps is not unreasonable. with the max filesize now at 1GB per video it's not like you can make it too big.
    Than Q so much , U r right , YOUTUBE reduces the bitrates , so when I increased bitrate , I got the desired quality.
  1. Does Anyone Know How to Recover Deleted YouTube Vids?
    By agrimensorguapo in forum Video Streaming
    Last Post: 19th Jun 2011, 22:03
  2. youtube is rejecting my AVI vids
    By Edward Powell in forum Newbie / General discussions
    Last Post: 21st Nov 2009, 12:50
  3. How do i put my youtube vids onto dvd? :-(
    By MADRASTA84 in forum Newbie / General discussions
    Last Post: 12th Nov 2009, 05:41
  4. Replies: 9
    Last Post: 10th Nov 2009, 21:35
  5. Replies: 2
    Last Post: 28th Oct 2008, 03:27
