VideoHelp.com Forum
    Hi There.
    I hope someone here can help me out. What I need to do is achieve the following.
    I need to have a machine, which will record 3 different radio stations simultaneously, and later in the day, record 2 TV channels.
    I was told I'd need 3 capture cards, which I have.
    I am also very confused on which Software I should use. Will Hyper Media Center do the trick? Or is there something else you guys (or gals) suggest?
    I also have a rough Idea of the system I will need, and it is this:
    [b]Motherboard- Gigabyte GA-EP41-UD3L
    CPU- Intel Dual Core E7500 @ 2.66Ghz
    Ram- 4Gb Corsair XMS Kit 800Mhz
    HDD- 500Gb Hitachi 7200 RPM
    Case/ Tower- Antec NSK 4480B-11
    Display- BenQ G2402 Full HD 1080p
    DVD- BenQ 22X DVD r/w
    Graphics Card- HIS ATI 4350 512Mb DDR2 64Bit
    Sound- Onboard 3D Audio
    Input- Genius Keyboard & Mouse Combo
    Operating System- Windows 7 Ultimate 64Bit
    The 3 capture cards are Unicenter R11 Remote Control Video Capture adaptors
    I am in desperate need of help, so, just like in the 5th element, Please... Help!
    Thanks in advance,
    Ginetti.
    Roll a 1D20...
    Do you have windows 7 64 bit drivers for these cards ?
    Do these cards have tuners (either FM or TV) ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Hi guns1inger,
    Yes, in the back of the cards there is a TV antenna socket and one for Radio. I can plug both into the wall, as we have specific wall sockets for TV and Radio (Because people in the building like to plug their radios into the wall for much clearer reception)
    However, if this card does not seem adequate, I am all for being recommended a card.
    Also a question: I understand with 3 cards i can capture from 3 different sources (3 different radio, or 2 TV and 1 radio at the same time for example)
    I am needing information on which software to use. I have tried out hypermedia centre, but I only had 1 card installed at the time. When I tried to capture 2 tv channels at once, it said "Cannot be done, conflict in scheduling"
    Roll a 1D20...
  4. Member edDV's Avatar
    Check GBPVR, SageTV and BeyondTV for FM radio support. Use the cards recommended in their system requirements.
    http://www.kiva.org/about
    Thanks for all the help thus far.
    I think I understand the situation a little clearer now. Am I right in assuming that to record upto 3 channels simultaneously, i'll need 3 capture cards. And that most the software will allow multipule recording of channels simultaneously?
    Cheers,
    Gineti.
    Roll a 1D20...
  6. Member edDV's Avatar
    Cheers,
    Gineti.
    Yes for multiple TV channels. Some cards have multiple tuners.
    I'm not sure for radio.
  1. Yamaha DRX-730; radio channels
    By takefive in forum Newbie / General discussions
    Last Post: 12th Jan 2011, 14:00
  2. How to record live radio and video streams?
    By Shadowofthedarkgod in forum Video Streaming
    Last Post: 15th Aug 2009, 19:40
  3. How to record virtual channels
    By GeoInMo in forum Newbie / General discussions
    Last Post: 13th Jun 2009, 22:00
  4. PVR will not record certain channels
    By sundown in forum DVD & Blu-ray Recorders
    Last Post: 13th Apr 2009, 04:56
  5. Replies: 5
    Last Post: 29th Nov 2008, 21:49
