I have a Humax PVR for recording satallite progs.
I recorded a series of 5 progs and wanted to put the on DVD
Normally I manage this OK as follows.
1) The Humax produces TS format, demultiplex using doom 9 projectx to get vid/audio files.
2) Then add the 5 files sets to dvdauthorgui and generate the DVD directory AUDIO/VIDEO
3) Use DVD shrink to ensure it all fits.
4) Then burn DVD.
Normally this all works great.
But DVDAUTHOURGUI complained about something so I set it "use alternate multiplexer".
It all seemed to work OK
I checked it on my PC with VLCplayer and no lip sync problems at all.
However on my DVD player the lipsync is very bad.
I made another DVD burn but that's as bad.
Any ideas ?
Thanks Jim
If you said exactly what this error message was, someone might be able to help.Originally Posted by prioryjim
I will get the message tonight !
Although use alternate multiplexer seem to get rid of the message!
Till later ...
After pressing "author DVD" you very soon get a popup ..
There was an unknown error.Please review the log for more information.
And the log is below
However if I tick the "Tools/Use Alternate Muxer"
The error goes away and the DVD completes.
But when burnt and played on a real DVD I get lip sync problems.
Any ideas, if not perhaps I could email as specified in log!
The LOG
DVDAuthorGUI 1.017 - 2/16/2009
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*(mplex)multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File C:\opt\RawFilms\xx\xxx.m2v looks like an MPEG Video stream.
INFO: [???] File C:\opt\RawFilms\xx\xxx.mp2 looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (C:\opt\RawFilms\xx\xxx.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 544
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 16:9 display
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 3791200 bits/sec
INFO: [???] Vbv buffer size : 176128 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (C:\opt\RawFilms\xx\xxx.mp2)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 16384 bytes/sec (128 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 0 no copyright
INFO: [???] Original/Copy : 0 copy
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 4003896
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16619
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [???] Scanned to end AU 21393
++ WARN: [???] No seq. header starting new sequence after seq. end!
**ERROR: [???] Sequence split detected 3 but no following sequence found...
*(mplex)multiplexing title: 2.....
Process aborted due to above error
There was an unknown error. Please review the log for more information.
Whatever program created the "C:\opt\RawFilms\xx\xxx.m2v" put some sequence splits in it, but apparently, no data following them. You should be able to remove the splits by processing your m2v file through restream (use 'Remove End sequence codes').
By the way, 1.019 is out. I'd recommend updating to it.
OK thanks , that seems to have sorted it. At least the bits I have watched had actors with the correct voices this time !
Wher can I get version 1.019
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 09:23 -
Strange lip sync problem
By joe_kargan in forum Video StreamingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 12:31 -
Formula for NTSC to PAL lip-sync
By macnab in forum Video ConversionReplies: 4Last Post: 11th Aug 2010, 10:16 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 15:53
