VideoHelp.com Forum
Thread: VOB to DVD
    Hi,
    We got 15 .vob files on PC which are generated by our camera. We did not have info files.
    We want to make Video DVD from these VOB files. I came across the following link and followed the procedure. But our final DVD pause at many places while playing. And the process of Vobedit and Ifoedit is also complecated.
    http://forum.videohelp.com/topic120021.html
    Is there any software where we can select the vob files and it will automatically join the vob files in the sequence added and create info files and write Video DVD?
    If not then, please let me know, why is it doing like that? Do we require to adjust "Sample Rate" in Infoedit?
    Please guide me, Thanks.
    That is a very old and not so good method.
    Are those 15 separate clips or one clip splitted?
    If one clip try join the vobs using vobmerge. Then import the vob in an authoring application like dvd flick(select in the options to no convert dvd compliant files) or tmpgenc authoring works etc.
    Thanks for reply,
    I don't know, which category in our case. We have recorded from our DVD Camera and as we got only one DVD for Camera each time we record to full DVD on Camera, We save that DVD on computer in vob file.
    We know the sequence of the VOB files. We have already named it from 1 to 15. On computer they are like following:
    VTS_01_1.vob
    VTS_01_2.vob
    To make it simple, can I just take one vob file at a time and directly use DVD Flick to author and then write that on DVD. It is fine to have 15 separate DVDs.
    Thanks.
  1. Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
    By jake61 in forum Newbie / General discussions
    Last Post: 5th May 2010, 15:12
  2. PAL .VOB to NTSC .VOB Sound out of Sync
    By zaque2004 in forum ffmpegX general discussion
    Last Post: 15th May 2009, 08:59
  3. Replies: 7
    Last Post: 21st Oct 2008, 19:10
  4. VOB to wav & m2v and back to VOB
    By GordRocks in forum Video Conversion
    Last Post: 13th Jan 2008, 05:44
  5. Cutting .vob file in .vob format only
    By rahul.never2far in forum Editing
    Last Post: 1st Oct 2007, 08:52
